Routing speed bleeder, just toss it in tunnel plate?
Can anything bad happen if I just toss the line inside the tunnel plate? The only thing I can think of, which I don't think is likely is it could come out and drag the ground, a zip tie could fix that potential problem.
I still have this stupid intermitten phantom leak of fluid that let's air in the line. I'm guessing it's not the slave as it only happens occasionally. I'm thinking it could be the oring that's in between master/slave. It drips on the driver side lt header close to the collector. Any thoughts on that as well?
I'm thinking about just getting the tick master, i just don't know if I should spend the money since I have a mcloud and it dosnt need the extra fluid.
regardless of what clutch your running, if you have the factory Clutch Master cylinder still in the vehicle, the Tick performance master will put a smile on your face, night and day difference, and thats on a stock clutch, so I can imagine the difference on a Hipo replacement clutch system as you have.!!
Received 1,261 Likes
I would route the bleeder line up over the bellhousing into the engine bay and mount it somewhere around the brake/clutch reservoirs that way you won't have to get the car in the air to bleed the clutch
I have mine routed on top of the torque tube so I can bleed it from inside the car. Have to take the boots off the shifter but still, It's super easy this way and you only need yourself.
Mine is zip tied up under the clutch master reservoir. Just kinda flop it out, hook up the one man bleeder and start pumping. Can bleed all the fluid out and get fresh in within 5-10 minutes with the car on the ground an no disassembly.
