Bad wheel bearing?
Bad wheel bearing?
02z, lowered on stock bolts. When I turn right at speed I hear a random pop pop pop....pop...poppopopop....pop. Sounds kind of like a grinding. popping gets faster the faster I'm going. No noise while wheel is straight or turn left. No play in wheel or brakes. Nothing that I can see is rubbing or hitting. Is this the wheel bearing? Something messed up in my power steering? Worn bushing? No codes present. Help me troubleshoot please
and 12 and 6 o'clock and see if there is any play?
raise and check the play. Could be. But, Usually you get other tell tale sounds leading up to that kind of failure, low frequency groan, etc.
If the bearing checks out...
Check the sticky's and composite DIY/thread collection. There are similar symptoms to what you are describing, and a simple fix, relating to the rear drive axle and spline shaft at the hub.
3 and 9 could be tie rod if 12 and 6 are solid. Bad bearing should be radial....loosed all around. See if you can see your tie rod end while moving the wheel...or pry at it and see if the joint is loose. Could also be inner tie rod but try to get a look at the assy while someone moves the tire.
If you replace I would recommend both sides. I just replaced all four (front and rear outters), I think they were $20/ea., from Rockauto. Mevotech or Moog.
Setting aside the loose wheel at 3 and 9 (you probably need to come back to that, likely tie rod)....if you say it made the same sound sitting at idle I would suspect the power steering pump/pulley. Try turning the wheel engine running, in park and see you get the same thing.
See if it changes when you run the A/C compressor....make sure harmonic balancer isnt wobbling under load.
The harmonic balancer recently came loose. I just reinstalled, pinned, and red locktite. Looks to be fully mounted to crank but I'll watch it while someone revs the engine. How would I diagnose the power steering pump? Would trapped air cause this? How would I better bleed it?
