Check Engine Light PCM Codes P0135 H C, P0141 C, P0155 H C, P0161 C
Old 09-16-2002, 10:54 AM
ISLANDBOY2
ISLANDBOY2's Avatar
Default Check Engine Light PCM Codes P0135 H C, P0141 C, P0155 H C, P0161 C
Got Check Engine Light on my 1999 Coupe. Have 3190 miles and light is not flashing. Checked DIC and got the following codes:
10 PCM (4) Codes:
P0135 H C
P0141 C
P0155 H C
P0161 C
Had a FLP Header System installed on 7/23/02. Install is with cats.
These codes are for the Heated Oxygen Sensors.
Any ideas on what to do such as ignore the light, bring it in to a dealer to check the sensors, replace the sensors, or erase the codes.
Old 09-18-2002, 10:18 AM
ISLANDBOY2
ISLANDBOY2's Avatar
Default Re: Check Engine Light PCM Codes P0135 H C, P0141 C, P0155 H C, P0161 C (ISLANDBOY2)
Checked the fuse for the Oxy and found it to be bad.
Replaced it and the Check Engine Light still on. Checked fuse and found it blew.
Guess need to have the HO2 checked.
Have FLP header system.
But car seems to run well. Also still have codes:
P0135 H C
P0141 C
P0155 H C
P0161 C
Old 09-18-2002, 11:09 AM
Scott97
Scott97's Avatar
P0135 HO2S Heater Ckt. Bank 1 Sensor 1
P0141 HO2S Heater Ckt. Bank 1 Sensor 2
P0155 HO2S Heater Ckt. Bank 2 Sensor 1
P0161 HO2S Heater Ckt. Bank 2 Sensor 2
Old 09-18-2002, 03:55 PM
ISLANDBOY2
ISLANDBOY2's Avatar
Went and erased the codes. Check Engine Light is now off. Got more 15amp fuses for "Oxy" fuse. But still the fuse blows when I start the car. Will check the HO2 later this weekend to see if there are any "shorts" in the wiring.
[Modified by ISLANDBOY2, 1:56 PM 9/18/2002]
Old 09-18-2002, 04:14 PM
chuckster
chuckster's Avatar
Check the O2 harness for pinched or melted wires. Might be melted to the headers.. :eek:
To Check Engine Light PCM Codes P0135 H C, P0141 C, P0155 H C, P0161 C
Quick Reply: Check Engine Light PCM Codes P0135 H C, P0141 C, P0155 H C, P0161 C
