Can you adjust headlight covers left/right?
Looking at this picture:
I understand that I can adjust the headlight assembly up/down with the 4 white colored screw and front/back with the 4 torx screws nearby but looking at that picture it doesn't look like there is any way adjust them left/right, is that correct?
My passenger side headlight cover rubs slightly with the hood when opening/closing and to prevent this I need to open the hood fully first, then turn on the headlight, then gently close the hood while pushing that headlight assembly away to prevent rubbing which is a pain, especially now that it's getting dark early.
I know that I might be able to adjust the hood front/back to make more room, but if I could adjust the headlight assembly instead, that would make it easier. Is that possible at all?
Thanks in advance
Thanks in advance
good news/bad news
The good news is that I was able to move my headlight covers in all directions in order to even the gaps. The bad news is that it was several years ago and I've forgotten how I did it- but I know that it can be done. If you're still stuck after a good try, PM me and I'll rip my covers off again for a refresher and then I can give you the info.
hades1 (10-22-2016)
Turns out you can adjust them left/right by loosening the 4 torx screws the whole upper section of the headlight assembly can be shifted left/right (even though on the picture above it looks like they can only be moved front/back).
Unfortunately that wasn't enough to avoid the rubbing of the headlight cover on the hood so I guess I am gonna have to adjust the hood then
Before adjusting the hood, you need to look at the gaps side to side and along the front of the hood. If the gaps are even, you need to look at how the headlight bucket is mounted. There may be some adjustment to the entire assembly. Don't make the hood wrong to "fix" an improperly mounted bucket. Fix the bucket. Was the car ever wrecked?
