Can not find a solution for clutch problem
C5 base 60k miles. Car will not catch any gear. Will not grind unless I put excessive force on it. Car has brand new clutch and pressure plate as well as master and slave cylinder. I have purged the clutch from the bottom several time as well as pumping the clutch to remove any bubbles from the master. After a few hours I try the car and no improvement. I have heard a couple of grown folk talk about the clutch needing a spacer?also Is there anything I need to check in regards to the torque tube? Any information as well as links to threads are very welcome. Thank you in advance
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I Believe In The Beer Fairy
It's possible the slave cylinder may need to be shimmed up.
St. Jude Donor '13-'14-'15
If you use a stock new clutch there should not be any issues However if you used non stock components then yes you can's simply bolt them in---You need to check for proper throw-out bearing to pressure plate clearance--Most likely it is now not in spec
thank you all for the feed back. according to a shop it needed a good purge and pressure plate was not properly installed. only thing is second gear will not catch 3rd when shifting at high rpms. but that is another story. thank you all
