Source for 99 C5 Z51 Rear Sway Bar Bushing
Anyone know of a source for the OEM rubber bushing for the 1999 Z51 rear sway bar? The part number I have found is 10401553 for 21.7mm bar but it seems to have been discontinued and not available anywhere I can find. I would like to replace my bushings but can't use poly due to rules requiring OEM equivalent replacements only. Anyone know of a substitute for this discontinued part?
Moog carries a pretty wide variety of rubber sway bar bushings, these are close at 21mm...
http://www.moog-suspension-parts.com/moog-k90396
These are 22mm...
http://www.moog-suspension-parts.com/moog-k90397
Good luck... GUSTO
These are 22mm...
Good luck... GUSTO
You can get Prothane bushings on Amazon. Measure your sway bars and be certain you've got the right ones. Use a caliper to be certain.
I can't use poly bushings and I don't see any Moog direct fit for my 99 z51 rear bar. The have a universal 21mm or 22.1mm (about 1/2 mm too big or small) but have no idea if either would work or fit the mounting.
Your call...
GUSTO
