2002 Coupe/ LS1 Upgrade Question
G'day All,
After having my 02 for around 3 years now, I have decided I want to look at doing some upgrades to my beauty.
I have looked around, and read a lot of reviews, and ideas from other fellow Corvette guys, and I like the idea of fitting a small Supercharger onto the engine.
The one I have looked at, is the one bolted to the side of the motor, and pipes over and into the intake manifold. Low profile, and will only, maybe, need for me to purchase a hood with a small bump in it?
I would like to know what is the best one to look at, with ease of fitting.
And while on it, what would I need to do to my LS1 to make sure it can run with the Supercharger? A recent engine I had with a 6-71, I had to do a lot of changes.
I know my Vette is only a Coupe, no Sports models here, but I want it to be my beast.
Thanks for any input.
Kevin.
We have pretty strict rules about fitting extra gear onto vehicles, height limits, view through the windscreen, major upgrades and the likes.
Kevin.
1/4 mile/AutoX
you know what they cost right ? 8 Grand !
O yes I do, but less then what it cost me for the new 6-71 and everything those many years ago.
Can't take it with me, can I, so when there's some spare, I like to use it on my toys.
But thanks for the heads up, I might not of known, and that would a scared me.
on the other hand, I just picked up a recent issue of hot rod magazine , with a $699 turbo article featured on the front cover . Worth a read, they say turbos are big because of the price points of these types of kits. Not what you are considering, but the more info the better, since you are still planning.
I talked to a guy who fabricated a turbo set up into the front fenders of his C4, said the cooling was his biggest problem, no kit for him. I couldn't turbo my C5 with nine kits, I would have to farm it out.
Andy's SC kits are popular. I don't have one, but he has sold a a ton of these.
A and A Corvette Performance
http://www.aacorvette.com
Phone number:
477-A Lambert St.
Oxnard, CA 93036
Phone number:
477-A Lambert St.
Oxnard, CA 93036
1/4 mile/AutoX
Phone number:
477-A Lambert St.
Oxnard, CA 93036
Phone number:
477-A Lambert St.
Oxnard, CA 93036
That's installed, but I doubt getting the car to Oxnard for the install would be inexpensive! The kit is about $2500 less than your figure. I have one on my '00 and it is wonderful. I've pulled mine off for other maintenance and looking at the installation manual it appears the initial installation wouldn't be too difficult for anyone with some mechanical abilities.
1/4 mile/AutoX
1/4 mile/AutoX
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
A SUPERCHARGER kit is the way to go. Depends on your GOALS for power and BUDGET, all you would need is a supercharger kit.
That being said, You MUST go by the old racers CODE.
FAST, CHEEP, RELIABLE!
Pick TWO cause you cant have all three!
For reliability , you should:
Change the VALVE SPRINGS and make the valve train more reliable. New upgraded trunions and stronger pushrods. New timing chain. The GM LS1 chain that you have is VERY WEAK and doesn't do well at all with added STRESS. Most people install a blower cam for optimal boosted performance. Good time to install the better chain, new performance lifters, new lifter buckets, oil pump and a timing chain dampener.
Don't know if your kit comes with a new dampener but you will have to get a new one as the GM Dampeners SUCK and fail without notice. The new one will need to be PINED to the crank!!!
Back to power goals. WHAT do you expect (or should I say desire) for a power increase??????? Depending on that answer, you may need to be very friendly with you accountant!
The more power you infuse, the more drivetrain work your going to need!
Traction!! That will be an issue. Better tires, with more meat! If you have RUN FLATS, they are NOT the best tires to put power to the pavement. At least not the run of the mill run flat tires.
Is your car an A4 or MN6???????? The A4 transmission will have a shorter life with added power. The third and fourth gear clutch packs and sun shell will fail in short order. If you have a CLUTCH, stand by for clutch issues caused by the extra power (read clutch replacement) How many miles on the car and drivetrain???
Wheel HOP. Most stock C5s have weak suspensions. Yes your corvette was only designed to support basically stock C5 Power. when you pass the 400-420 RWHP level, shortcomings will rear their ugly heads.
Your SHOCKS are most likely very worn or useless and will not do well with the added power. Transmission and engine mounts will most likely need to be up-graded for best performance.
COOLING. Depending on where you live, cooling could be a BIG factor and you may need to install a bigger aftermarket radiator. A4 will need a good aftermarket cooler. On most supercharger kits, the radiator is repositioned to lay flatter to properly fit the tube that connect the intercooler outlet to the TB.
This is a short list.. Keep you wallet tuned and ready support!!
BC
BC
G'day All,
Kevin.
Kevin.
1/4 mile/AutoX
BC
BC
1/4 mile/AutoX
