transmission fluid & filter change
Old 10-29-2016, 09:23 AM
ace8th
5th Gear
ace8th's Avatar
Default transmission fluid & filter change
i am about to change the tranny filter and fluid on my 99 c5.
also changing the 1-2 shift solenoid.
my question is should the tranny fluid be drained hot or cold?
i have the DIY manual on this but id doesn't say either way
to drain it , hot or cold.
input would be greatly appreciated!
thanks
john
Old 10-29-2016, 09:46 AM
oelarse
Support Corvetteforum!
oelarse's Avatar
As far as I know the oil should be at operating temperature .
But take care when you drain the oil ,
Old 10-29-2016, 09:50 AM
ace8th
5th Gear
ace8th's Avatar
Default i have that put it does not say
that is just a pre exquisite to the entire procedure,
it does not say at step 1
Old 10-30-2016, 12:42 AM
foggy
foggy's Avatar
Wait Til It's Cool.. You won't get any benefit either way..
So don't make it more difficult
Old 10-30-2016, 11:06 AM
jim993
jim993's Avatar
Cool is easier.
But when refilling, you will bring it up to temperature and dribbling out the fill hole before putting in the plug-
Old 11-02-2016, 11:53 AM
sean.b
sean.b's Avatar
im sure its probably "better" warm, but realistically unless you have issues and expect chunks floating around that arent already stuck to magnets (which would mean you're kind of screwed, imho) i doubt it matters significantly. if you want ultra peace of mind without all of the fun 2nd degree burns, just drain and flush it a couple of times. transmission fluid is cheap.
Old 11-02-2016, 03:09 PM
Bill Curlee
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The A4 REFILL PROCEDURE is extremely specific on how to do it and do it CORRECTLY!
If you do NOT follow the procedure to the LETTER,,,,,,,,,,,,,,,,,,,,,, You better be ready to purchase another transmission or repair the one you have,
READ AND FOLLOW THE SERVICE MANUAL GUIDLINES/PROCEDURE!
Just drain it cool!
BC
Old 11-02-2016, 03:11 PM
sean.b
sean.b's Avatar
the only part to be specific on is filling as the convertor is moving. i dont think refilling a 4l60e is dramatic enough to break out the caps lock and underlines..
Old 11-02-2016, 03:17 PM
meadowz06
meadowz06's Avatar
St. Jude Donor '09 and '13
Bill is THE MAN! Listen to what he says. He knows his stuff!!!
Old 11-02-2016, 03:24 PM
sean.b
sean.b's Avatar
yea i know he knows his stuff, but this isnt rocket science. have you ever done this procedure before? the hardest part is cleaning up the mess it makes. 4l60e's tend to suck, but ive never seen one damaged by changing its fluid.
Old 11-02-2016, 05:49 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you fill it wrong and run it runs low on fluid you will find out how it feels when it goes South! Seen it tooooo many times to count!
Not enough fluid to cool it properly and make proper shifts makes it very unhappy.
BC
Old 02-06-2017, 04:11 PM
jakazz425
jakazz425's Avatar
BC
New to posting to this forum, been an avid reader for a while though. I have some questions that line up pretty well with this topic.
Question:
I have a 2000 Vert with an LS1 and 4L60e in it, it has 236k on the clock and the transmission went out. I drained and removed the transmission and differential and TT. Im getting the 4l60e rebuilt by a good reputable person out here in Oklahoma. But im unsure of how to fill it afterwards with it being dry. Also unsure on any procedure of filling the Differential and torque converter. I have a yank torque converter with a 4000 stall i believe, the previous owner had it installed, not sure on mileage of the tc but not sure how to tell if it is going bad either. so with it mounted to the tt still is there a way to make sure its full and primed? and is there a write up to get everything back together properly? I see dissassembly and removal alot but no re-assembly so I gather its basically just the exact opposite of disassembly? Also, what fluid should I be using to fill the diff and transmission with? will Mixing fluid with whatever is currently still in the TC cause any problems?
Thanks In advance guys!
Old 02-06-2017, 04:22 PM
PDQC5
PDQC5's Avatar
Can you be more specific on what actually went wrong with the transmission, if there is any debris /contamination of the oil then the Torque converter needs to be flushed if not pulled apart to clean it out and tested for correct operation
Old 02-06-2017, 07:39 PM
Rob 02
Rob 02's Avatar
I use the factory service manual for almost everything. It is a real asset especially regarding torque specs. If you are doing your own work you really should score at least a used set of manuals. There is so many aluminum parts that every nut and bolt is critical.
Old 02-06-2017, 08:37 PM
jakazz425
jakazz425's Avatar
I lost 3rd and 4th gear, and 2nd started going out. To be more specific, started getting jerks and slippage in 3rd and 4th gear. So when I drained the transmission fluid it was dirty red but no major debris coming out, I didnt check the magnets to look for larger debris before I removed it. The fluid coming out of the TC right now is dingy red same as transmission. No Debris from there either. Sadly I didnt do a TC test prior to tearing it down (stall test) so im not 100% sure on the TC. As i stated its a Yank TC and the place that is rebuilding my tranny will give me a new Stock TC and fluid for 150$ but I dont want to replace the Yank TC with a stock if I dont have to.
Old 02-06-2017, 10:16 PM
PDQC5
PDQC5's Avatar
I would touch base with Yank and see what they recommend .
Old 02-07-2017, 07:08 AM
runner140*
runner140*'s Avatar
Never seen one damaged by changing its fluid?...I have.
To transmission fluid & filter change
Quick Reply: transmission fluid & filter change
