Headlights- one up, one down
I replaced the driver side head light motor. When I turned it on, the new motor is down when the light is on and up when it's off. I manually cranked it down but they still aren't in sync. I even changed the way I had the linkage bolted up and still same result. Is it me or the part?
headlight, one up one down
Read this thread and I believe that you will see what you did wrong on the re-assembly of the motor linkage:
https://www.corvetteforum.com/forums...-one-down.html
yep, they just need to be synced properly
