Indicator Lights around dash display
My 04 has lights that are starting to go out in the little buttons that go around the right side of the dash display. Are those easily replaced? If so, where can I find the bulbs?
I replaced the lights in the buttons on both sides of the cluster. It is necessary to remove the cluster from the car to replace them.
I purchased the replacement LEDs from JW Motoring (a forum vendor). I justified the replacement of all due to the amount of work it took just to get to them.
I went with LEDs over the stock incandescent bulbs because of the brighter light that they put out.
Was not that bad a job just a little time consuming.
Good luck getting yours replaced.
