Maintenance on super low mileage Z06.
I just bought a 2002 Torch Red Z06 with 8,7xx miles on it. As a 15 year old car I'm going to do some standard maintenance items to ensure everything is fresh before I start really driving it. So, now a question for anybody else who has ever picked up one of these super low mileage cars. I figure I should probably be safe and do all of the fluids and a tune up.
- engine oil
- transmission fluid
- rear differential oil
- brake fluid
- power steering fluid
- engine coolant
- clutch hydraulic fluid
- spark plugs
- fuel filter
- valve springs (build date 01/02 so better safe than sorry)
Am I missing anything? It has a blackwing air filter on it so I have left off the air filter. I'm also pretty sure (haven't checked yet) that it has the skip shift eliminator and the CLB installed already.
Is there a consolidation somewhere of the recommended fluid types, quantities, and filters?
Thanks!
- engine oil
- brake fluid
- engine coolant
- spark plugs
- fuel filter
Thanks!
Tires?
I would personally put new tensioners on the list as well just for peace of mind with the new belts.
I'd also check out the rubber suspension bits, on my 7k mile FRC the endlinks were falling apart.
Windshield wipers before you need them
Thermostat
plug wires don't hurt.
If you check out the last page of my thread you can see that I'm about to go through the same thing. along with some of the other funky issues I've had along the way.
Thermostat
1/4 mile/AutoX
Lmc5 !!!
You have a good list to start with. I wouldn't worry about the spark plugs but would consider replacing the wires if they look dried out. The OEM plugs and wires are good for 100k miles. Then again, they aren't that expensive. Belt tensioners would be low on my list too.
1/4 mile/AutoX
Do plugs and wires for sure. Plugs are just gonna get harder to get out as time goes on.
Use dielectric grease in boots. anti seize on plug threads.
Looks like you got list pretty well covered..
I'd do tires IF they are original/over 7 years old.
Shocks may be something to do too.
Nice purchase. Just an FYI though. Do some research and search for threads about factory yellow valve springs breaking in Z's from 02 -04. You will find many cases where the springs have failed. The springs are brittle. If you are going to remove the plugs and wires I would go ahead and remove the a valve cover and see if your Z is still rocking the factory yellow springs. With the low mileage I would assume they are. You can buy replacement springs like the PAC 1218 Beehive's from PAC Racing. Not trying to steer you to a certain spring just one that comes to mind. Not sure but the spring issue may have made a "sticky" in the ZO6 section.
Not trying to alarm you, just want you to be aware. I'm the original owner of my 02 vert, so have been around the C5 for awhile.
Also, don't want to start a range war here but there are also may threads in here about whether or not to use anti seize on plugs. Most manufactures of plugs don't recommend it as they already come with it on them. I would go to the manufactures web page and see.
Back in the day of iron heads yes. But different story with aluminum heads.
Just some food for thought. Enjoy your new ride.
tires tires tires
you don't really "need" to do the plugs but it wouldn't be a bad idea. same with wires. wires can start to leak as they age as the insulator around them starts to crack.
run a hot batch of techron through it too. 40-60oz in a tank of gas, if the injectors have any varnish from sitting this helps
redline d4 atf works wonderful in the transmission. i would use mobil1 in the rear end, 75-90w. the redline 75-90 is good for racing but the lsd additive is a bit too slick. i like a little more lockup. wix makes your fuel filter. your spark plug is ac delco 41-110, denso makes an identical OEM wire. dex cool coolant, either from GM or a major brand. brake fluid, best value is the ATE super blue or typ200
valve springs are the GM replacements $65-70 for a set of 16 from summit racing or others. as low of mileage as you have you probably don't have to change the valve seals but they do harden with and and new GM valve seals are $40 for all 16. they take about 15 seconds to install with the springs off. valve cover gaskets should be fine. easy to replace if one leaks.
