very small coolant leak
Cruise-In VI Veteran
Check the coolant hoses on the throttle body, one hose comes from the rad, the other hose comes from the heads steam tube. Use a flashlight and mirror to aid in the visual inspection.
Cheers,
Goose
Cheers,
Goose
89nascar (01-25-2017)
A lot of people bypass those. As for any Hp gains it is questionable but does help in TB removal
i checked the TB hoses with the air filter duct removed and both dry , looks be coming from under the intake and is wet at the front edge of the lifter valley cover , very slow leak no drips on the ground or at the rear but with leak parked or running
Completely clean it until it is dry, then while you are under the hood have someone start the car and then keep your eyes on it, if nothing have them rev it a few times. The only place I can think of it is coming from is the head coolant pipe lines because I'm pretty sure the intake manifold has no coolant that runs through it. Take another picture but come out a little ways so it can be seen entirely in the area it is happening.
89nascar (01-26-2017)
OK, thanks for the update.
Coolant can be pooled on the valley cover or even soaked into the foam on the underside of the LS1 Intake.
There is no coolant running through the intake but there is a steam pipe running under the intake and on top of the valley cover, see pics below.
Recommended approach to verify where and what is leaking coolant.
With the engine off and cooled to ambient temp, pressurizes the coolant system with a coolant system pressure tester hand pump, (check your local auto parts stores as they rent this tool).
NOTE >DO NOT Exceed the pressure rating (PSI) as indicated on the cooling system cap when pressurizing with the hand pump as damage to the cooling system can occur, (I pressurize to between 5 to 8 PSI and I’ve been very successful locating leaks).
Connect the tool to the expansion tank, pressurize system and search the cooling system for obvious leaks and repair as necessary.
Post up what you find.
Cheers,
Goose
Cheers,
Goose
i have checked the steam pipe at the heads and no leaks , i think removing the intake then pressurizing the system to see all of the steam pipe might be the best way as there is a lot of grime on top of the valley cover , maybe a leak at the center of the steam pipe assembly ?
Cheers,
Goose
Cheers,
Goose
Hello, don't pull the intake just yet...Perform the coolant system pressure test first and locate the leak before you remove any items...
You maybe surprised where you find the leak...
Cheers,
Goose
Cheers,
Goose
The following 2 users liked this post by 69:
89nascar (01-27-2017),
El original (01-29-2017)
