Budget Interior Sound Desdening
Good to know. I will take a bit of the material and experiment with it for the remainder of the winter to see how much water it dents to absorb.
My plan is to cover the entire rear deck and wheel wells with the material. This is not intended as a perfect solution. This is for me, a budget solution to an otherwise expensive upgrade.
Currently, with no deadening what so ever, it is a horrible music listening space. Yeah, I know, it's a car. Not only that, it's a sport car.
I did the entire interior of my previous C5 using the same Frost King. Pulled out all the interior and covered every panel with FK and double on the tunnel........but I have to say I was disappointed in the results. It reduced interior noise and heat a bit, but not nearly as much as I had hoped for. When I bought my current 03 I thought about doing it again......but I really don't think the results warranted the cost and labor.
I just got my first Vette yesterday, a 2000 model. I can't believe the road noise. It has BB PRT exhaust, but most of the noise is road noise. I read all through this post, and a similar one on another forum, both talking about the Frost King. I then found pre-cut insulation panels at exoticvette.com. Comes with full instructions of disassembly and installation. $215 plus $30 shipping. I am SERIOUSLY considering ordering it. Anyone have any experience with this?
St. Jude Donor '15
I just became aware of Frost King Duct insulation. From what I can see, it is a better solution than that tar-based peel and seal. Frost King Duct insulation seems to be based on a butyl rubber 1/8 inch pad with a foil backing, so no tar melting during the hot summer months. I plan to use the Frost King Duct insulation product.
Generally, I will be placing the duct insulation under the carpets covering the trunk floor and rear wheel wells. Is that correct? From one of the photos It looks like you are using the duct insulation on the outside of the wheel well. How will that hold up against the weather and the elements?
You are in a very special club now, that of Corvette owners. I suppose you know that Vette owners greet one another on the streets. Enjoy your Vette. Post some photos of your new toy.
I'd do the back wheelwells first since you don't have to take
the interior out.
Then you can evaluate if you want to do the interior.
Back wheelwells was enough for my vert.
This is not my car but I also have a partition in the trunk like this one
the interior out.
Well,
Ok, nuff nonsense for this AM. Have a wonderful morning in church and a super day.
Dave
Road Noise?
Fiberglass insulation with backing? NO, NO, NO!
Why is there always time to do a job over, but never enough time to do it right the first time?
I have used the peel-and-seal product by Co-Fair. It is used for weather-sealing around homes at the door and window frames before trim is installed. I can't tell any difference between it and FatMatt. Well, except for the price and the branding.
We had some of the Co-Fair product left over from some work on the house and I used it inside one door of my 'vert. No stink. Sticks like a leech. Gives the door a more solid feel and sound - a satisfying thunk - on closing.
Unless you enjoy paying the Vette Tax you should consider this alternative.
gpruitt54 (01-29-2017)
I am certainly not the "last word" on sound deadening and insulation of Corvettes, but I have done a bit of work on mine. Anyone who does the wheel wells with this is in for trouble (IMO). Moisture will get in there and be a habitat for bacteria, spores, fungus, etc.
The wheelwell fits tight.
I ran some silicone over the seams with my fingers.
You could also stuff it with plastic grocery bags.
David Shiel (01-29-2017)
#34
#35
Got say
#37
Good for a laugh
but if you don't want to use fiberglass which is waterproof then crumpled plastic bags are an alternative.
#39
It is sound deadening for a hollow area.
It was just extra stuff.
If you don't like it don't use it.
The Frost King is the main sound deadener
along with the partition.
You guys seem hung up on this.
I don't care if you think it's a bad idea.
I'm happy with how quiet my vert is.
What ideas are you offering up?
#40
No it is not completely ineffective.
I would like to understand more about the Frost King material inside of the wheel well. The material is exposed to the elements and weather. Why used the material in that location? In this same area, I could see some of the fiberglass insulation sticking out, also exposed to weather and the elements. Are you concerned about the materials getting wet and dirt exposed.
