Power loss Issues, possible limp mode
Also, it was right at 58 psi last time I had it on.
I would check the compression at this point.
If you can do both a leak down test and a regular test it will give more information obviously. If you do a leak down test and have a cylinder that is leaking fast, try to hear where the leak is with a mechanics stethoscope or ear on a long screw driver. Listen to see if it is hissing through the intake or exhaust manifolds (this would suggest a valve related issue).
If the leak down test checks good but the dynamic compression isn't then you may have a clogged exhaust.
Any comp test will provide some information.
Would a clogged exhaust not give out a check engine light?
Is it easiest for you to lift the car up and remove the mid pipes or remove a few spark plugs and do a compression check? What tools do you have at your disposal?
By the looks of your car, I am assuming that a big truck backed up on the hood in a parking lot. For liability reasons, the insurance company declared it a total loss. The previous owner took off his expensive exhaust and quickly threw threw the old one back on.
If he stuck the exhaust back on in haste then I would want to raise the car and check the hole thing out.
If there was a performance exhaust on the car then it is likely that there were a few more performance modifications to your car that may be beneficial.
That's my current setup. It shouldn't be too hard to take the exhaust pipes down, but I'm not sure how to check the cats. It's all welded so I couldn't get a good look. All I could do is put a leaf blower to it.
I just finished cleaning the MAF sensor and throttle body. Throttle body wasn't bad but the MAF was very dirty. I saw slight improvement. I can feel some of the power back but the idle is still rough, still doesn't have a lot of power, and the rpms still take a second to come back down. Still no check engine light.
I am am going to try the exhaust next. Going to try to get it today but need to wait for the pipes to cool down. I'll save the compression and leak test for last. Could the TPS also be causing the issue?
Here is a pic of the rear O2 btw
Don't forget to check for intake leaks as well. Vacuum lines, PCV, AIR system... might want to make sure everything between the MAF and the throttle body is OK as well. Speaking of the MAF, you might want to get that checked too. It sure looks like it may have taken a pretty good whack in the wreck, based on the condition of the hood.
Just a guess here, but if the throttle position sensor isn't working, could that cause issues?
How do you check the fuel pressure? I said earlier it was at 58 but that was oil pressure. I don't see a pressure gauge at the fuel rail.
I check all vacuum lines by spraying carb cleaner with no effect. I am about to do a compression test. What should the psi be at each cylinder?
You can get a fuel pressure gauge from Harbor Freight or from a friend.
At the end of the fuel rail there is a Schroeder valve.
The pressure should read around 58psi at idle and raise with throttle.
#33
I borrowed a friends scanner today just to get a better idea of what was going on. Of course there was no code, but I'll post some of the data I got while the car was idle.
#34
Also, I did both the fuel pressure check and compression test.
Fuel pressure was 57 when key was in on position, and 58 when the car was running. I also let it sit in on for about 10 mins to see if I lost fuel pressure, and it actually went up by 2 psi.
Compression test was good too. 178-180 on all 8 cylinders. Almost no deviation in PSI.
The spark plugs were black when I pulled them out however. These were brand new spark plugs. I've turned on the car maybe 10 times since putting them in.
Side note: I also found an unplugged wire that I have no idea where it goes.
#40
The fuel trims in your pics are out of whack. One side is high positive and the other side is high negative. Maybe your front O2 sensor wires are swapped side to side. Try swapping the plugs on the sensors.
