19x9.5 and 20x11 verona
Good morning,
I bought a set of xo luxury wheels the verona in that size for a good price and wanted to know what size tires should i buy i have a 97 base model and should i get them painted or powder coated.
Unsure about the offset, but to maintain around the same as factory diameters;
275-30-19
315-25-20
If you want a new color, powder coat.
Not fond of the band-aid tires on a C5, but all that matters is that you like them.
275-30-19
315-25-20
having a problem finding that wide of tire in a matching set. now i was able to find a set of 245/40/19 for the front and 295/25/20 in a lexani tire
Stock tire diameters are;
Front: 25.35/25.68 (Z/base)
Rear: 26.13/26.66 (Z/base)
245-40-19 = 26.71, way too tall
295-25-20 = 25.81, way too small
This combination will not work at all. You need around an inch bigger out back, not the other way around.
And as noted above by Emerica88, the offset is wrong also (unless you're comfy with big spacers, might even rub inside otherwise?); wrong wheels for the car.
