Supercharged C5 Arizona Heat 160 or 190 Thermostat?
Hey guys, I have a supercharged 01 c5. In the midst of my winter projects, just got done swapping out engine and tranny mounts to hinson polyurethane. While doing the job I discovered that my lower radiator hose going to T-Stat is seeping coolant right where it connects to the T-Stat. The hose is close to 20 years old and feels spongy compared to other hoses and has lost its rigidity if you will, I don't see any damage on the hose. Ordered a new upper and lower radiator hose as preventative maintenance.
Currently in the process of interviewing for a new job located in AZ and would require relocation. I have never had any issues with overheating, in summer in city traffic I'm typically between 205 and 215 temp. The previous owner of my car listed that my car has a DYI 190 degree thermostat, which sounds like a stock temp t-stat. I don't know when it was replaced and given it's a fair amount of work to get to with having to remove the SC I'm planning on replacing the t-stat as preventative maintenance.
Should I go ahead and replace the t-stat with a lingenfelter 160degree one or go stock? Would it be beneficial at all to AZ heat or would I be better off turning on my fans at a lower speed, sticking with stock? If the job doesn't pan out I don't want to have to go back to a stock t-stat because of the wrong choice. Thanks.
I would use a 180* over a 160*.. only because the LS likes to run
warm- not just for emissions , but for engine longevity
That being said, It really matters more (in Arizona) When you
have your fans kick on and off.
tommypenguin (02-26-2017)
Thanks, I will just keep the thermostat I have now and mess with my cooling fan settings in hptuners if I move.
Received 1,260 Likes
stock or 180 at the lowest, just have the fan settings adjusted... a dual core radiator and fan upgrade is not a bad idea either... a 160 stat will not make your car run cooler at idle with the ac on when you need it most, that is where the fan adjustment comes into play... personally I don't like 160 stats, as stated above during cold temps the car may run too cool while at cruising speeds and it will also take the car longer to get up to operating temp so the heater might not work as well as usual
