LED DRL/Turn Signals
Looking for guidance. I installed LED DRL's with Switchback Bulbs and a common load resistor connected to my flasher in the dash. Initially they worked fine then I began blowing bulbs x4 now. I changed the 3157 sockets, changed the bulbs again and I was good for about 2 hours. Now the one side works as it should and the other side will work with the headlights on, and zero with the DRL position?
Where to go next??
Where to go next??
This is what I bought
I know that the switchback bulbs were a pain in the *** to put in. I thought I was going to break the or the wire socket putting them in. Also both my housing had holes in the from the stock light bulbs burning a hole in the I fixed this also. The other parts I used replaced the hyperflash issue with a new relay inside of using the resistors at the bulbs. Someone reported that it smells like something buring using those.
I found a loose connection going to my new socket and all is well.
You also must either replace or repair the housing as more than likely there is a hole in it. I could not find the video that show the hole. I used duct tape to fix mine while it was installed in car.
Open the headlight with the turn **** all the way up. Take black cover off. If you look down were the bulb goes more than likely above it you will see a hole above it. There is a gray plastic piece with a cicrle this is were I used the duct tape. I if find the video I will post up. I think it was from foggy on youtube.
Please read all the way to bottom there is one wire you dont cut.
https://www.corvetteforum.com/forums...problem-2.html
Or buy the 60.00 premade flasher
Cruising
DRL LED Switchback Issue....Please help!?!?!
I installed the LED switchback bulbs and resistors on my 2009 6 speed cp. The DRL's come on amber unless I have the parking lights on....... Reading different threads here; it is indicated to be a disappointing but normal function. Yet, returning to my purchase information it clearly states the DRL's will be white and only turn signals and flashers will be amber! Further, NOTHING comes on when I first start the car and for several minutes thereafter! I do NOT have the parking brake on and do have it gear. This gets topped off with me being a bit "thick" to say the least! But, I could use some help for clarification PLEASE? Thanks!
Bob
Bob
