Drivers Seat, Telescoping Column doesn't work Idea's Anyone
drivers seat was moved as for forward as possible and a wire was caught on the seat rails and pulled out of the electrical connector. The seat would not move in any direction.
The lumbar and seat bolsters were working before I replaced the wire in the connector now nothing works on the seat or telescoping steering column.
Swapped seat switches from driver to passenger seat and switches work fine. I have electrical power to switch and Seat Control Module.
DTC's show "No Comm" with SCM. Fuses for driver and passengers seat were swapped and are ok.
1/4 mile/AutoX
did a wire get pulled out of something else also ???
Thanks Pounder, I looked and double checked all the electrical connections could not fine any other broken or loose wires or connection. Just don't understand, the steering column and seat bolsters and lumbar support was working prior to the re connection of the pulled out wire.
1/4 mile/AutoX
Did the battery disconnect procedure and still no change. Looks like a used SCM $$$ is in my future. I'm going to remove the seat in the morning and manually adjust it to the rear at least it will be derivable while I wait on the SCM to arrive.
Update on OP I changed the SCM and seat harness and still could not get the power seat or steering wheel column to operate. Replaced the battery everything is working, still receiving code A6 SCM-no communication, but everything is working so I'm done.
And, of course
Dave Shiel
Dave, all the fuses were fine as long as the drivers seat keeps working and the only code I get is A6 SCM -No Comm I can live with that. I did attempt to trace the wiring circuit and I had power to the SCM just not enough volts. The telescoping wheel, the door control module and the SCM must communicate with each other is my guess.
Monty
Monty
You mentioned you replaced the seat harness, but you still have in place the old mating connector, so the possibility of some deformed pins affecting the integrity of the connection is still there, right?
Another weak point is the connectors inside the door's accordion. Bill Curlee has documented this issue extensively. Check this post out for more details.
Yes, the door control module and the seat control module are connected to the serial communication bus. The seat control module controls the seat and also the telescoping function of the wheel.
Rangerdog1 (03-19-2017)
I did a check for loose pins in each of the connectors both under the seat and on the door, I didn't find any. However I broke one of the wires when I was inspecting the black connector coming from under the carpet below the seat. I soldiered it back together that was the first thing I found the first time I removed the seat about 10 iterations ago. I drove the car around for over an hour and the only code I get is the No Comm for the SCM every thing else works. I wonder if the SCM has to be sync'ed with a TECH 2 or not. Thank you, I've learned a lot from just reading the CF members post and answering.
I read Bill's thread you noted in the earlier reply and ordered the connectors that were recommended. When they arrive I will remove that seat one more time and follow your recommendation on the electrical K wire. It will be a week before I can get back to work on this it will a few days for those connectors to arrive. Thanks
Thanks SuperTom, I'm going to live with the no comm for the SCM until something else goes wrong. I have no other DTC's and everything works, telescoping wheel, seat moves in all directions and the lumbar and seat bolsters work. I did repair the broken wire but still no comm with the SCM. I'm going to enjoy driving it for now.
