Why does my remote code keep getting dropped?
2nd Gear
For the last month or so the rfa code for the remote door unlocker has been dropping the code every time I reset it. I have change the battery. Any help is appreciated!
Thanks,
Steve
Thanks,
Steve
Re: Why does my remote code keep getting dropped? (StevenV)
Your sensor is going out.. it is inside the plastic panel behind the driver seat - past the speaker..
My 99 did the same - so if you have a warranty - go taker her in.... :cheers:
I have same problem but only on fob #2. It stops working after a couple of hours after resynqing the fob.
I just received a new fob which I ordered from Ken Fichtner. I'll do the fob relearn first thing in the morning and post back if it solved my problem.
Roger
Roger
If this happens with only one fob then thats where your problem is. If both fobs then there is probably something wrong with the receiver but my money is on the fob itself-seems to be a relatively common problem.
Re: Why does my remote code keep getting dropped? (weaver)
It's pretty easy for the contacts in the fob to bend; take the battery out and check the contacts.
Re: Why does my remote code keep getting dropped? (Terry34)
Terry, you were right, it was the fob.
I did bend the contacts on the old one before I ordered the new one but still same.
Glad this problem is solved :cheers:
Roger
Roger
Re: Why does my remote code keep getting dropped? (rhoeven)
Glad it all worked out for you... :cheers:
