check engine light reset?
how would i reset a check engine light that came on because of a problem maf sensor.
i have tried:
reinstalling the old maf sensor
unpluging the - side of the battery for 30 seconds
(right now i just disconnected the battery in hopes that a longer disconnect will do it)
thanks for the info
i have tried:
thanks for the info
Re: check engine light reset? (KEPRGHT)
Since you determined that it was the MAF sensor that was causing the check engine light then I would assume you know how to read out the codes through the DIC. To clear the code bring it up on the DIC and press reset :)
https://www.corvetteforum.com/techti...D=26&TopicID=1
[Modified by SFVetteman, 6:15 PM 12/27/2002]
