how do you......
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Re: how do you......
Assuming your battery is already disconnected...(if not, disconnect it for a couple minutes):
Connect the battery.
Run or drive the car until the water temp is at least 176 degrees.
Park and let the car idle for 5 minutes.
Shut off ignition for at least 30 seconds.
Then go enjoy your car!
These were the instructions provided to me from Halltech.
:cheers:
:cheers:
Re: how do you...... (Mordenkanen)
Hey Mordenkanen,
please do also a SEARCH through the database in the tech-section. It is for sure, you will find a tremendous amount of real valued information about the details to do the procedure.
GOOD LUCK Buddy ! .......and enjoy the power of your Car.
Joe. :seeya
Joe. :seeya
