Biggest size valves for LS1/6 style heads?
Old 01-21-2003, 10:30 AM
Mike TexaSS
Mike TexaSS's Avatar
Default Biggest size valves for LS1/6 style heads?
What is the biggest size valve someone has put into a LS1-Ls6 style head (4.8 5.3 5.7 6.0)? Im talking big inch stroker heads 434 cid and up. Biggest intake valve and exhaust valve and what head flows best with theese huge valves?
Old 01-21-2003, 11:06 AM
kromberg
kromberg's Avatar
Default Re: Biggest size valves for LS1/6 style heads? (Mike TexaSS)
With a bore of 4.125", one can fit 2.125" intake and 1.625" exhaust valves. These are the size valves used on the C5R heads :)
Keith
Old 01-21-2003, 01:31 PM
MattG
MattG's Avatar
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: Biggest size valves for LS1/6 style heads? (kromberg)
I have 2.08 / 1.60 valves in my ARE Stage III LS1 heads that are on my 436ci.
I dont see a need to go any bigger than that unless you are going with LOTSA lift and LOTSA duration.
ARE usually uses 2.55/1.57 or 2.08/1.60 in their big cube Stage III heads.
To Biggest size valves for LS1/6 style heads?
Quick Reply: Biggest size valves for LS1/6 style heads?
