Just tried my first batch of Toluene...
Location: My barber didn't know when to quit... Do you?
Pinging is down significantly and the throttle response is much crisper. I am very happy with it so far.
I used 1.5 G mixed in with a full tank of gas which should take me from 91 octane (best I have here) to 93 octane which is perfect for my car.
The only downside is the cost, around $8 extra per tank but well worth it I think to stop the pinging.
The octane booster I tried was crap and did nothing.
Re: Just tried my first batch of Toluene... (2000^C5)
I tried some of that over-the-counter "octane booster" when I had my 84. I put in a chip and the engine would knock like crazy. I ended up taking it out.
Re: Just tried my first batch of Toluene... (redls1c5)
<BLOCKQUOTE>code:<HR><PRE> 1 2 3 4 5 6 7 8 9 10
1 104.0 108.3 110.5 111.8 112.7 113.3 113.8 114.1 114.4 114.6
2 99.7 104.0 106.6 108.3 109.6 110.5 111.2 111.8 112.3 112.7
3 97.5 101.4 104.0 105.9 107.3 108.3 109.2 109.9 110.5 111.0
4 96.2 99.7 102.1 104.0 105.4 106.6 107.5 108.3 109.0 109.6
5 95.3 98.4 100.8 102.6 104.0 105.2 106.2 107.0 107.7 108.3
6 94.7 97.5 99.7 101.4 102.8 104.0 105.0 105.9 106.6 107.3
7 94.3 96.8 98.8 100.5 101.8 103.0 104.0 104.9 105.6 106.3
8 93.9 96.2 98.1 99.7 101.0 102.1 103.1 104.0 104.8 105.4
9 93.6 95.7 97.5 99.0 100.3 101.4 102.4 103.2 104.0 104.7
10 93.4 95.3 97.0 98.4 99.7 100.8 101.7 102.6 103.3 104.0
</PRE>[/QUOTE]
Table shows the effect of adding tolulene - example - 2 gallons of tolulene to 10 gallons gas = 95.3 octane
the base octane in this table is 91
[Modified by '97 C5, 8:04 AM 6/7/2003]
Re: Just tried my first batch of Toluene... ('97 C5)
What is the base octane of the gasoline used, or does it matter? If I start with 93 octane, why add a gallon of tolulene to 10 gallons of gasoline to get 93.4 octane?
Pretty interesting thread. I think I'll try this stuff and see what happens....maybe I should have gone with a higher compression ratio, anyone game for 12.5:1? :crazy:
Phillip
Phillip
Just a note: USE GLOVES and face protection if that stuff is even going to splatter on you a little bit. It is a wicked poison. Otherwise, enjoy the extra performance!
http://www.epa.gov/OGWDW/dwh/c-voc/toluene.html
What are the Health Effects?
Short-term: EPA has found toluene to potentially cause the following health effects when people are exposed to it at levels above the MCL for relatively short periods of time: minor nervous system disorders such as fatigue, nausea, weakness, confusion.
Long-term: Toluene has the potential to cause the following effects from a lifetime exposure at levels above the MCL: more pronounced nervous disorders such as spasms, tremors, impairment of speech, hearing, vision, memory, coordination; liver and kidney damage.
Sorry, the base in the table was 91 octane here's the same table with 93 as the base..
1 105.0 109.0 111.0 112.2 113.0 113.6 114.0 114.3 114.6 114.8
2 101.0 105.0 107.4 109.0 110.1 111.0 111.7 112.2 112.6 113.0
3 99.0 102.6 105.0 106.7 108.0 109.0 109.8 110.5 111.0 111.5
4 97.8 101.0 103.3 105.0 106.3 107.4 108.3 109.0 109.6 110.1
5 97.0 99.9 102.0 103.7 105.0 106.1 107.0 107.8 108.4 109.0
6 96.4 99.0 101.0 102.6 103.9 105.0 105.9 106.7 107.4 108.0
7 96.0 98.3 100.2 101.7 103.0 104.1 105.0 105.8 106.5 107.1
8 95.7 97.8 99.5 101.0 102.2 103.3 104.2 105.0 105.7 106.3
9 95.4 97.4 99.0 100.4 101.6 102.6 103.5 104.3 105.0 105.6
10 95.2 97.0 98.5 99.9 101.0 102.0 102.9 103.7 104.4 105.0
11 95.0 96.7 98.1 99.4 100.5 101.5 102.3 103.1 103.8 104.4
12 94.8 96.4 97.8 99.0 100.1 101.0 101.8 102.6 103.3 103.9
13 94.7 96.2 97.5 98.6 99.7 100.6 101.4 102.1 102.8 103.4
14 94.6 96.0 97.2 98.3 99.3 100.2 101.0 101.7 102.4 103.0
15 94.5 95.8 97.0 98.1 99.0 99.9 100.6 101.3 102.0 102.6
16 94.4 95.7 96.8 97.8 98.7 99.5 100.3 101.0 101.6 102.2
17 94.3 95.5 96.6 97.6 98.5 99.3 100.0 100.7 101.3 101.9
18 94.3 95.4 96.4 97.4 98.2 99.0 99.7 100.4 101.0 101.6
19 94.2 95.3 96.3 97.2 98.0 98.8 99.5 100.1 100.7 101.3
20 94.1 95.2 96.1 97.0 97.8 98.5 99.2 99.9 100.4 101.0
</PRE>[/QUOTE]
</PRE>[/QUOTE]
Re: Just tried my first batch of Toluene... (Tom Steele)
about the hazards before working with Toluene and proceed
with caution - for your own sake and for the sake of those
around you.
Re: Just tried my first batch of Toluene... (Slalom4me)
:iagree: all carbon 6 membered rings are very toxic. benzene causes leukemia and toluene is bad. just be careful. you dont want to end up with horribe medical conditions because you wanted your car to stop pinging.
Does Tolulene, xylene etc. ruin catalytic converters? Just wondering if anyone knows. :p:
joel (Bink) :cheers: :steering:
Re: Just tried my first batch of Toluene... (Poolman)
EPA has found MOD FEVER to potentially cause the following health effects when CORVETTE OWNERS are exposed for relatively short periods of time: minor nervous system disorders such as fatigue, nausea, weakness, confusion.
Long-term: MOD FEVER has the potential to cause the following: more pronounced nervous disorders such as spasms, tremors, impairment of speech, hearing, vision, memory, coordination; liver and kidney damage. :jester
Re: Just tried my first batch of Toluene... (binksZ06)
Yes, you should be VERY careful with it. BUT it was used for years as a parts cleaner in the auto industry. It isn't nuclear waste. ;)
http://www.atsdr.cdc.gov/tfacts56.html
Use basic precautions and you will probably be ok. If your going to be messing with it a lot, I'd wear gloves. And if you go the 55 gallon drum method, make sure it SEALS WELL if you keep it in your garage. You do not want it building up in a closed area.
Re: Just tried my first batch of Toluene... (jawsski)
So, you have no access to 100-octane racing unleaded? That might be a better choice, and there are distributors that will sell it to you in small (barrel) quantities.
http://www.vpracingfuels.com/
St. Jude Donor '05
Re: Just tried my first batch of Toluene... (Matt Black)
Re: Just tried my first batch of Toluene... (wallstAL)
Dang, Al, I need that business. Union 76 "Competition 100" is $2.45 a gallon around here...but this hyar is NASCAR country... <chew> <spit> :D
I've seen alot of talk on these forums that octane boost does very little for stock or even moderately modified LS1/6s.
As I understand it, they are designed to run optimally on 92-92 octane and that the computer doesn't really "allow" any benefits from higher octane fuels.
Any comments?
Any comments?
