Kelley Performance Grand Opening Specials!!!!
As a lot of you know, we are hosting our fist DynoDay this coming Saturday July 12th at Kelley Chevrolet. We should have a very nice turn-out starting at 9am sharp!! In celebration of our grand opening, I would like to take this opportunity to let you know about some of the performance specials we will have availble for a very limited time!!
1: Kelley Performance Heads/Cam Special: This package consits of the following highest quality parts:
Brand new CNC machined LS6 heads with a raised compression ratio of aprox 11:1, Hardened pushrods, Custom Comp-Cams Camshaft 224-228 113LS .540 lift, all original new OEM Gaskets, Bolts and fluids, Mobile 1 oil change, Professionally installed with a before and after dyno printout using our newest state of the art Dynojet 248 with Wideband O2/ Professional LS1 programming of your car's PCM and a final dyno run and printout. This package along with your aftermarket intake and headers should produce aprox 480-500 FWHP or 410-425 RWHP. This combination will offer you excellent drivability and be perfect for use as your daily driver as well as the weekend racer.
First 5 cars ONLY!! 4995.00
Headers Special: Stainless Works Long Tube Headers!! These are some of the finest quality headers we have seen to date. Meticulously crafted with Stainless Everlast 304 and a OEM type quality fit. We have seen aprox 18-20 RWHP and up to 22 Ft/Lbs of Tq with these headers and the 3" X-Pipe.
Headers Speicial: 1049.00 With the thick 3/8" Flange
Headers Installation: We will install your FLP, Stainless Works, TPIS or other type long-tube headers. The installation includes a before and after dyno run with Wideband 02 printout to show you your exact gains!! The below price is based upon a bolt-in installation without welding reqired. If welding to your main cats is required, there will be a small additional charge for the welding that will be discussed with you prior to any work starting.
Speical Installed Price: 450.00
Donaldson Blackwing Special. 249.00 Installed!! Please add 11.95 for 2001-2003 vehicles as a special adapter is needed.
If you have any questions at all, please let me know. All of us here at Kelley Performance are looking forward to seeing everyone this Saturday at our DynoDay. Remeber, come rain or shine as we will be there with our dyno ready for action!! :)
[Modified by Brian@KelleyPerf, 10:10 PM 7/8/2003]
[Modified by Brian@KelleyPerf, 6:06 PM 7/9/2003]
[Modified by Brian@KelleyPerf, 6:07 PM 7/9/2003]
Re: Kelley Performance Grand Opening Specials!!!! (Z06TheKid)
I just ordered the Blackwing from http://www.exit28motorsports.com/ for $199 including shipping.
Mark
Re: Kelley Performance Grand Opening Specials!!!! (mdhmi@yahoo.com)
Mark
Mark
Re: Kelley Performance Grand Opening Specials!!!! (qs01coupe)
Do you provide a warranty with the parts and work?
We warantee our installation and installed parts if purchased through Kelley Performance Center.
If a customer brings his own parts to us and the parts fail or cause other problems, then the customer would be responsible for our our labor and any other costs to repair the problem. It would then be up to the customer to get with the company where the parts were originally purchased for them to replace them or to refund any monies spent as a result of the failed part/parts in question.
Re: Kelley Performance Grand Opening Specials!!!! (Brian@KelleyPerf)
Thanks Brian!
A couple more questions. How long do you warranty the work and your parts? Does this effect the factory warranty?
My friend has his 2000 mag red vert in your shop now. I can't wait to see the dyno results!
Received 1,408 Likes
2017 C7 of the Year Finalist
St. Jude Contributor
If I were in FL I might have been pondering being one of the first 5 for the H/C job. Sounds like a deal to me and something I've lately been thinking about. :thumbs:
Thanks Brian!
All of our professionaly installed work is waranteed for a period of 12 months or 12,000 miles.
Regarding the factory warranty, if a performance part fails and causes the failure of another part, the factory warranty will NOT cover this damage. If the car has a failure of a unrelated item, then the warranty coverage would be honored.
If you have any questions, please let me know...
Re: Kelley Performance Grand Opening Specials!!!! (Glennm27)
Brian I emailed you about my headers, I recevied them today :cheers:
Re: Kelley Performance Grand Opening Specials!!!! (CoolSSBoy)
What will the "normal" pricing be after the first five cars? How much RWT also? Thanks.
AJ
AJ
Right now we are only advertising our grand opening prices. Expect there to be an aprox 10 percent increase in the price after the specials are over.
With our CNC LS6 heads and our custom grind Comp Camshaft, we are seeing aprox 410-420 RWHP and 390-400 RWT through headers and high flow Cats. It is important to note that the car retains excellent drivability and has a nice broad torque curve. When I get back to the dyno, I will download the file and post the graph.
