Do the LS1's have leaking intake gasket issues like the L98's and LT1's?
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Do the LS1 engines have leaking intake gasket issues like the L98 and LT1's of C-4 fame? :confused:
☠☣☢ Semper Ebrius ☢☣☠
Re: Do the LS1's have leaking intake gasket issues like the L98's and LT1's? (onedef92)
Re: Do the LS1's have leaking intake gasket issues like the L98's and LT1's? (Scissors)
LS1/6 intakes are plastic, with 8 small pressed in gaskets (one on each port).
Not only do they not leak, they are nearly infinitely reusable.
Jon
http://www.ls1howto.com
Jon
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Re: Do the LS1's have leaking intake gasket issues like the L98's and LT1's? (jmX)
no oil touches the intake, so...no oil leaks :thumbs:
except through the PCV :cuss
Onedef92,
For the C5's, Chevrolet has replaced the leaking intake manifolds from the L98's and LT1's with defective column lock modules and defective fuel gauges on the LS1's.
Re: Do the LS1's have leaking intake gasket issues like the L98's and LT1's? (1999 White C5 Coupe)
Onedef92,
Re: Do the LS1's have leaking intake gasket issues like the L98's and LT1's? (aurik)
Actually GM has been working from front to back in fixing the leak problems -- on the C5 they have made it all the way back to the differential! :hurray:
No the C5 intakes have been pretty much maintenance free.
Onedef92,
Too funny.
Tom
USAF Retired
