Found Tach signal wire under drivers side of dash <BIG PICS>
Old 09-04-2004, 01:20 PM
T_Vert
T_Vert's Avatar
guys where exactly is this harness that has these white wires in it? The pics wont work for me and all of my harnesses are covered in tape. Id hate to have to remove all the tape to find the right harness.
dave
Old 09-04-2004, 03:01 PM
T_Vert
T_Vert's Avatar
NM I found it
thanks
dave
Old 09-04-2004, 08:02 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The pics will NOT work for me either! Whats up with that?
What do I need to do to be able to view the picctures????
Bill Curlee
Old 09-04-2004, 09:10 PM
Mike Mercury
Mike Mercury's Avatar
I need the pics. Can you email them to me?
tim-yvonne@juno.com
Old 09-04-2004, 09:30 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
PLEASE include me in that request for the pics!! bill327@msn.com
I will be ordering a shift light one day soon
What are some of the better shift lights out there??
Bill Curlee
bill327@msn.com
Old 09-05-2004, 08:57 PM
Flyin'Brian
Flyin'Brian's Avatar
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
You can find some of the pic's here
Flyin'Brian
Cruise-In I Veteran
Old 12-29-2004, 04:04 AM
Cscokd
Cscokd's Avatar
I just wired mine up this last weekend following Brian's lead. I found the tach (white) wire by using a safety pin to make momentary contact and watching the Raptor activity (set it at 1500 rpm for test purposes). I connected my red (power lead) up to the pink wire in that same bundle which is the 12V on/start ignition voltage to the instrument cluster. If you use a different 12V source that is always hot as some have suggested, you can't change your Raptor settings because it ignores switch setting changes until a power cycle. At least that's how mine worked. I picked up ground at the grounding block just inside the left kick panel. All clean and works great. Be sure to use some tiewraps to tidy things up before you close it all up. I can't stand rattles Thanks Brian for all the help.
John
Old 01-02-2012, 03:18 PM
2 GTOs
2 GTOs's Avatar
St. Jude Donor '11-'12
Originally Posted by RoadRebel
Let add 1 thing.
A lot of cars have the same color (White) for all three.
The easy way to test which on you need is by using a regular test light connected to ground. With the key in the run posistion. Probe each wire. You will find when you probe the tach wire it will pulse the tach when you probe it. If its one of the other white wire you will see dash indicator lights turn on..one being the skip shift, I forgot the other.
Phil
I tried to use a test light with the ignition on, engine off. 1 lie lit the text light , the others did not. No movement on the dash. Then I started the engine and checked voltage. 1 had 13, 1 had zero, 1 had like 5-6 v. Is the last one the tach?
Old 01-15-2012, 07:06 PM
yakisoba
yakisoba's Avatar
I have an observation and a question:
Observation: One of the three white wires is more towards the outside of the sheaf than the others. It looks to me like that causes the discoloration in that wire. It may be that is always the tach wire since all of these harnesses are the same (mostly).
Question: What do you ground your probe to in the cockpit?
Old 02-04-2012, 12:24 AM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Ya...where do you put the other 2 wires?
Old 02-05-2012, 07:28 AM
2 GTOs
2 GTOs's Avatar
Other 2 wires? You just tap into the white tach wire. You leave the other 2 wires alone.
Old 02-05-2012, 01:48 PM
  #33
chuckster
chuckster's Avatar
Great Tip!!! I plan to use this when I install my Shift Light.. I have an Autometer Shift-Lite.
I was dreading going to the PCM..
Old 02-05-2012, 02:14 PM
  #34
bumble-z
bumble-z's Avatar
Flyin' Brian, thanks for taking the time to help all of us here on the forum in regards to making it so much easier, finding the tach wire for installing our
shift lights!
I found your thread a few years ago when doing the shift light install.
yakisoba, in regards to finding a ground inside the cockpit.
There are places (steel) to ground to, right where the tach wire lives.
Thanks again Flyin' Brian.
Here is where I ended up installing my shift light.
Pretty much unnoticable with the dust cover on.
Old 02-05-2012, 09:51 PM
  #35
VGLNTE1
VGLNTE1's Avatar
ya, the red and black wire for power and ground. Those still need connected yes?
also, how do you tie in the green wire the white tach wire? Im an electrical noob. Can i just peel back the white shealth and wrap the green wire around it and electrical tape it?
Old 02-06-2012, 10:53 AM
  #36
chuckster
chuckster's Avatar
Use one of these from Radio Shack.. IT just squeezes over the white wire and then piggy backs the Green wire.. The picture shows a Black Wire being tapped and the Red Wire being added.. But you get the point.. NO Cutting or Soldering involved.
Wire Tap-In Squeeze Connectors (10-Pack)Model: 64-3052 | Catalog #: 64-3052
Old 02-06-2012, 06:02 PM
  #37
VGLNTE1
VGLNTE1's Avatar
Thank you!
To Found Tach signal wire under drivers side of dash <BIG PICS>
Old 02-16-2012, 10:02 PM
  #38
VGLNTE1
VGLNTE1's Avatar
Ok, new problem. Have the light hooked up. Led's flash like they should. Have it set to 3100 to test it and i know i have the right tach wire because i cut it in half. Lol. And the light wont flash when i hit that rpm. Thoughts?
Old 02-16-2012, 11:45 PM
  #39
RX-Ben
RX-Ben's Avatar
fwiw, it is really easy to pick from the pcm. You might be hunting for a while to find the correct white wire and not find it (my experience).
Old 02-16-2012, 11:51 PM
  #40
bumble-z
bumble-z's Avatar
I found it easily on my 03 Z, by following Fly-n -Brian's pictured write up.
Quick Reply: Found Tach signal wire under drivers side of dash <BIG PICS>
