New wheels/tires balanced twice...still get nibble at 75-80mph
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Anyone know what could be wrong and can it be corrected? Balance was done at Discount Tire by same tech each time. Problem was lessened with 2nd balance...took additional .5 grams on each front tire/wheel assembly. He said bead may have seated better after driving a few days. But I still have some nibble between 75 and 80 mph. I'm thinking I should get on-car balancing done somewhere. Could wheels be defective? There was some noticeable runout when the wheels were spun on the balance machine. :cheers:
Re: New wheels/tires balanced twice...still get nibble at 75-80mph ($$$frumnuttin')
If there is noticible runout or wobble. Tire balance will not correct it . There is no need to balance on the car. Is the runout in the tire or wheel. You can check by holding a block near the inside wheel lip and turning the tire and wheel assembly. Tire balance cannot correct a wheel or tire that is out of round. A professional tire installer [yes there is such a person] can tell you that right away. Good luck
Re: New wheels/tires balanced twice...still get nibble at 75-80mph (Brian@KelleyPerf)
I had a problem that several people thought was tire balancing. It was a light vibration and noise that sounded like rmmmmm, rmmmmm, rmmmm. The noise could come in at about 70mph and get louder the faster I went. Took it back to Discount Tires. They said everything was perfect. Finally took it to my local GM dealer. Turns out that it was the left rear wheel bearing. Luckily it was covered by warranty.
