Cigarette Lighter not working..help
Old 09-04-2003, 10:56 PM
BQuicksilver
BQuicksilver's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
Default Cigarette Lighter not working..help
I typically plug my G-Tech Pro into the lighter, but last week the tip of it's plug came off in the lighter and my cig lighter hasn't worked since. I checked the #1 fuse i the passenger side footwell, it is okay.
Any ideas? :cheers:
Old 09-04-2003, 11:16 PM
RockinC5
RockinC5's Avatar
Default Re: Cigarette Lighter not working..help (BQuicksilver)
Fuse #7 is also for a cigarette lighter, i think fuse #1 is for the cigarette lighter in the console... although i'm not sure. Check fuse #7 and see if it is blown, hopefully it is and replacing it will solve your problem :)
Good luck!
Old 09-05-2003, 07:48 PM
Arkay
Arkay's Avatar
Mine crapped out too and the wire was pulled out from behind - probably by me when I had he console out to find my parking lot RFID card that slipped behind the ash tray lit What PIA to remove the console again for the 3rd time.
Old 09-07-2003, 10:26 PM
BQuicksilver
Default Re: Cigarette Lighter not working..help (MANNY)
Fuse #7 is also for a cigarette lighter,..
:thumbs:
#7 mini fuse is the one for the cigarette lighter. (It also powers the orange wire for the accessory pigtail, at top left of BCM.
That was it! Big thanks for all the support! :cheers:
Old 01-09-2010, 12:59 AM
Gregory0729
Gregory0729's Avatar
Since your problem is solved, hope you don't mind me jumping in. I unplugged my ipod adapter from my lighter and when I plugged it back in - no power. Figured it was a fuse, since the adapter works in my other cars. Sometimes I have power and sometimes I don't, so I don't see how it could be a fuse. Any ideas?
Old 01-09-2010, 09:00 AM
JerzeyJoe
JerzeyJoe's Avatar
Probably a loose connection behind the lighter. Happened to me when I had my center console apart for a radio upgrade.
Old 01-09-2010, 10:33 AM
pear
Support Corvetteforum!
pear's Avatar
Ohio Events Coordinator
St. Jude Donor '09
Loose wire here, seems to be the leading cause. ..."pear"
To Cigarette Lighter not working..help
Quick Reply: Cigarette Lighter not working..help
