Anyone ever use Toluene
Old 09-09-2003, 06:30 PM
402Sam
402Sam's Avatar
Default Anyone ever use Toluene
I keep hearing about this toluene you can get from sherwin williams paint store. Supposely it is 110 octone. You need to get a Marvel mystery oil with it or it will eat your fuel lines. All the supra guys run this around here. I am goin to try it this weekend. Just wanted to know if anyone else has tried it.
Old 09-09-2003, 06:33 PM
USA Muscle
USA Muscle's Avatar
Default Re: Anyone ever use Toluene (sprayedc5)
Don't really think it does anything for the octane but I've used it before as a very good fuel system cleaner - that's mainly what it is - a strong disolving cleaner. I won't keep in my fuel system but just to clean it out.
Old 09-09-2003, 06:35 PM
Sweet98
Sweet98's Avatar
Default Re: Anyone ever use Toluene (USA Muscle)
I heard of people using it before they go take emissions tests
Old 09-09-2003, 06:38 PM
90 droptop
90 droptop's Avatar
Default Re: Anyone ever use Toluene (Sweet98)
I used it with my GN. Lets you run lots of boost. Do a search on it...
Old 09-09-2003, 08:28 PM
kumar75150
kumar75150's Avatar
Default Re: Anyone ever use Toluene (90 droptop)
There is no point to using it unless you are running forced induction or more than 11:1 compression.
Dont waste your time.
Old 09-09-2003, 09:57 PM
C5inWV
C5inWV's Avatar
I used it with a carbureted Camaro 383. It made a difference on that car. I've used the highest octane I could find at local tracks (in the Vette) and it didn't seem to make any difference. Fuel injection is more efficient than the Holley 750 double pumper.
Toluene used to be sold as an octane booster in the "B12 Chemtool" line of products. It was better than "104+." They pulled it off the shelves in many places because kids "huff" it to get high.
By the way, the toluene made the Camaro faster up to a point. All the boosters I used eventually melted the catalytic converter (which had been left in place for state inspection.) Once the converter was shot, it lead to a series of problems and poor driving until I figured out the problem. I wouldn't add too much to the tank if you still have the cats.
Old 09-09-2003, 10:25 PM
402Sam
402Sam's Avatar
Default Re: Anyone ever use Toluene (6krpm)
No kitties here so that is not an issue, if its not worth my time and money then I wont do it.
Old 09-09-2003, 10:34 PM
KorbenDallas
KorbenDallas's Avatar
It worked on my '81 vette that had a 383 with a 750 double pumper on it. I've read on the forum that it does little for C5's; for that matter neither does octane booster (which is what toluene is).
Old 09-10-2003, 11:55 AM
2ndVette
2ndVette's Avatar
Default Re: Anyone ever use Toluene (FroDaddy)
I would disagree. Toluene is about 114 octane and does raise the octane rating of your gas and is quite effective. Do your own research and you will discover it's benefits.
Old 09-10-2003, 03:49 PM
SFVetteman
SFVetteman's Avatar
I'm not sure but if I remember correctly, the main ingredient in the octane boosters that you see in the stores is toluene.
Old 09-10-2003, 04:14 PM
Richin Chicago
Richin Chicago's Avatar
It is 114 octane and is easy to figure how much to add to boost octane.
See: http://www.elektro.com/~audi/audi/toluene.html
Old 09-10-2003, 06:32 PM
Flintstone
Flintstone's Avatar
Default Re: Anyone ever use Toluene (Richin Chicago)
I use it all summer. You can use Toluene or Xylene, depending on what is available and what is cheaper.
If used in reasonable quantities, it is not eating any fuel lines, ruining your cats or otherwise. Most fuels already contain toluene as an octane enhancer, and all you are doing is raising that percentage.
It makes a huge difference in my performance, and lets me get away with running without an intercooler in the Dallas heat.
Expensive as crap at SW though - $7 - 9 depending on location. You have to buy it in BULK :crazy: , and do your best not to inhale, nasty nasty stuff
F
Old 09-10-2003, 07:09 PM
kumar75150
kumar75150's Avatar
Default Re: Anyone ever use Toluene (2ndVette)
Not needed on a low compression NA engine.
Old 09-10-2003, 07:48 PM
2000^C5
2000^C5's Avatar
Location: My barber didn't know when to quit... Do you?
Default Re: Anyone ever use Toluene (kumar75150)
Yes I use it and it seems to help my pinging problems in the heat a bit.
Old 09-10-2003, 08:08 PM
boblackhardtop
boblackhardtop's Avatar
Default Re: Anyone ever use Toluene (2000^C5)
Assuming you need more octane than what's available at the pump, you can use Toluene at NO MORE than 20% mixture w/ pump gas.
Toluene is preferable to Zylene because pure Zylene is prohibitively expensive. The off the shelf/ hardware store Zylene contains impurities that you don't want in your car.
Old 09-10-2003, 08:09 PM
Black$heep
Black$heep's Avatar
I work for the airlines. We use it all the time to activate glues and remove glued panels. It is like MEK but is doesn't evapoarte as fast. Tough stuff keep off skin. It is very rough on plastics and rubber, so be carful. :eek: :thumbs:
Old 09-10-2003, 10:46 PM
frick
Default Re: Anyone ever use Toluene (Flintstone)
Generally, the Ace Hardware and True Value hardware places have Tolulene much less expensive that SW, SW is a good paint store but their solvent prices are generally higher that other places, currently 8.99 a gal in PA.
HIH
To Anyone ever use Toluene
Quick Reply: Anyone ever use Toluene
