Help: oil pressure guage is pegged
Old 10-07-2003, 08:55 AM
XportC5
XportC5's Avatar
Default Help: oil pressure guage is pegged
The other day I start the car and the oil pressure guage peggs over to the max. I pull up the digital read out and its says 130 psi and doesn't move under any conditions, oil level is fine and no codes set in the DIC. Bad oil pressure sending unit ? Any body else experience this? my C5 a '99 is probably around 80K miles.
:confused:
Old 10-07-2003, 11:24 AM
APT
APT's Avatar
Default Re: Help: oil pressure guage is pegged (XportC5)
I had exactly the same symptoms at about the same mileage. Replacing the sending unit solved the problem.
Old 10-07-2003, 11:46 AM
ICULUKN-C5
ICULUKN-C5's Avatar
Default Re: Help: oil pressure guage is pegged (APT)
sounds like the oil pressure sender... While you are in there... you may as well put a LS6 intake on..... :D
Old 10-07-2003, 11:50 AM
Patches
Support Corvetteforum!
Patches's Avatar
The yellow arrow directs you to it. Of course, you don't have to take nearly this much stuff off to get to it. :lol: Just the intake that sits over it and the components that allow you to pull the intake manifold.
Old 10-07-2003, 11:52 AM
ICULUKN-C5
ICULUKN-C5's Avatar
Default Re: Help: oil pressure guage is pegged (Patches)
word of advise... dont strip the nut that holds the sensor in... big PITA
Old 10-07-2003, 04:00 PM
XportC5
XportC5's Avatar
Thanks everyone, as usual great advice !! I love this Forum..
:cheers:
To Help: oil pressure guage is pegged
Quick Reply: Help: oil pressure guage is pegged
