Piston Slap or Carbon Knock?
St. Jude Donor '06-13,'16-'17, '19
On my 40,000 mile 99, on cold start up I hear a knocking sound that lasts for about a mile. This just started happening a few weeks ago.
I can run through the gears near redline and the car won't knock on cold start for several days. When the knock starts again I can run the engine again near redline to clear the knock again for a few days.
Tom
Tom
Re: Piston Slap or Carbon Knock? (TCW)
Since it is a '99 ( like mine :) ) you might want to check if any of the piston rings might have come loose ( a common problem with older wets :sad: mine had it ). :seeya
Location: Various places in California. Not currently aflame.
Sounds like piston slap to me. Knocking from carbon deposits typically happens when the engine is hot, especially under high load/low RPM conditions.
What you are describing sounds like carbon induced piston slap. Using the word knock gets people confused and they start to think of pre-ignition (which the carbon will also cause)
Do the decarb procedure (the one where you put the cleaner in the spark plug holes). This should help eliminate some of the carbon on your piston tops.
