Oil pressure 31-35 PSI!!!!
Re: Oil pressure 31-35 PSI!!!! (Q8Y)
That sounds like normal pressure for a warm to hot engine. When cold, most C5s run around 40+lbs and see the pressure drop as the engine warms. You are probably OK, depending on your outside temps, which I presume are going to be going up. :yesnod: :)
Received 3,812 Likes
St. Jude Donor '03-'04
what kind of oil pressure do you expect?
