AC Delco 75P-7YR AGM Battery Discontinued
Just got off the phone with AC Delco: the 75P-7YR AGM battery is discontinued. Apparently, not enough sales for this advanced (Absorbed Glass Mat), lightweight battery. I weighed the old one at 33lbs and the Optima Red Top (75/86) at 34lbs. The closest AC Delco match is the 75-7YR (Professional Series, as opposed to the 75P-7YR Professional Platinum Series). The 75-7YR is maintenance free and 735 CCA, but spillable (can't tip over), and is estimated to weigh around 35.5lbs (I didn't weigh it).
Thus, the closest match to the original lightweight, non-spillable battery is the Optima Red Top 75/86 (CCA @ 720). While ~1lb heavier than the original AC Delco AGM, it has a much better CCA at 720 as opposed to 500 CCA (the 75P-7YR was rated at 550 CCA).
While at the dealer, I checked an '04 Z06 on the lot: it had an 86-6YR, non-maintenance free battery (you can add water), with the old-style top posts.
AC Delco did verify that they cancelled the UPF UltraGuard Gold oil filters, then brought them back due to Corvette/car-club demand. Perhaps the same could happen with the AGM batteries. Otherwise, the Optima Red Top 75/86 is the closest match.
Re: AC Delco 75P-7YR AGM Battery Discontinued (johnC5)
Nice work on all your info. I heard the red top was one of the best batteries for high-end stereo usage also. :cheers:
Re: AC Delco 75P-7YR AGM Battery Discontinued (slong)
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Re: AC Delco 75P-7YR AGM Battery Discontinued (c5chris)
I thought that was the yellow one. :confused:
In addition to the 720CCA RC90 75/86 (or 75/35, could be called 75/86/35: size class) ~33.1lb (I measured 34lbs) Red Top, Optima also sells a ~38.8lb 800CCA RC 110 34/78 (larger size) Red Top.
The deep cycle Optima Yellow Top is a 34/78 size battery weighing ~43.8lbs, with a 750CCA and RC120. The deep cycle batteries can be drained to very low levels, many times, and still be recharged OK. This would work well when running a powerful sound system while the car is not running. You won't want to use a normal starter battery for that application (such as the Red Top).
For those not into the jargon: CCA = Cold Cranking Amps (a higher number is considered 'better', giving more cranking power (generally resulting in a bigger, heavier battery with more cells), and RC = Reserve Capacity (in minutes, based on a standard benchmark).
Optima specs, info here: http://www.optimabatteries.com/products/index.asp
(Look under 'Starter' and 'Deep Cycle').
Also, the factory new car warranty on the starter battery (C5/Z06) is 36mo/36Kmiles. If the AGM (or other type) fails, you can get it replaced under warranty. I believe I read a post where someone replaced their stock (AGM?) with an Optima Red Top and got it paid for under warranty. Check with your local dealer (since the OEM AGM is no longer available from AC Delco).
[Modified by johnC5, 3:01 PM 12/9/2003]
Location: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Thanks... Maybe I'll get a decent battery when I return the POS Delco... :smash:
