How do I know my clutch is slipping - CorvetteForum - Chevrolet Corvette Forum Discussion
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace
Old 12-16-2003, 11:18 AM   #1
ICULUKN-C5
CF Senior Member
ICULUKN-C5's Avatar
Default How do I know my clutch is slipping
My clutch recently changed. The clutch is NOT slipping, however the pedal feels different. The clutch engages closer to the floor now... WTF? I am getting less pedal travel now.
ICULUKN-C5 is offline   Reply With Quote
Old 12-16-2003, 12:20 PM   #2
IMQUIK
CF Senior Member
IMQUIK's Avatar
Default Re: How do I know my clutch is slipping (ICULUKN-C5)
Sniff check. :)
IMQUIK is offline   Reply With Quote
Old 12-16-2003, 01:09 PM   #3
Monster231
CF Senior Member
Monster231's Avatar
Default Re: How do I know my clutch is slipping (IMQUIK)
Quote:
Sniff check. :)
:iagree:
Youll eb able to smell the clutch smelling, also your RPM's will be considerably higher. The change in pedal pressure is probably due to climate change. The fluid expands and contract as the temps change, your clutch will adjust after a couple of days or miles of driving
Monster231 is offline   Reply With Quote
Old 12-16-2003, 08:40 PM   #4
RichieRich
CF Senior Member
Default Re: How do I know my clutch is slipping (Monster231)
I've noticed my pedal has a lot more play in it now that it's gotten quite a bit colder. Once the car is warmed up and/or it's later in the day and warmer, it feels normal. I went out on the first really cold morning the other day and there was no engagement until it was about halfway to the floor. After about 15 minutes it was fine. I've had the car for 3 years and never noticed this though. Time for new fluid?
RichieRich is offline   Reply With Quote
Old 12-16-2003, 08:49 PM   #5
VERYSOON
CF Senior Member
A good way to tell if your clutch is slipping is to drive up a steep incline. Put her in 4th or even fifth going around 30 mph and romp on her a bit. If your rpm rises rapidly and your speed increases slowly (relatively) your clutch is slipping. Bet you don't have a problem, though.
VERYSOON is offline   Reply With Quote
Old 12-16-2003, 11:05 PM   #6
VetteDrmr
CF Senior Member
VetteDrmr's Avatar
Quote:
... The clutch engages closer to the floor now...
That's expected. As far as I can tell, the master/slave relationship doesn't adjust like the brakes do. So, if you work out the geometry (a friend of mine and I did just this earlier this week), when the clutch disk is new (thickest) the engage/disengage point will be towards the bottom of your pedal travel. As the disc wears, that point will move upwards. My clutch has 110,000+ miles on it now, and the engagement point is towards the top of the travel.
HTH, and have a good one,
Mike
VetteDrmr is offline   Reply With Quote
Old 12-16-2003, 11:52 PM   #7
NVR BRNG
CF Senior Member
I'm confused with your original post. Note your question: "How do I know my clutch is slipping?"
Then you go on to say, the clutch is NOT slipping, but the pedal travel is different.
Yes, if you do have slippage, you will smell it and hear the motor rev up more than accelerate under some load.
Otherwise, the posts here give some possible areas to check. Are you getting complete engagement to begin with? If you're confident in a proper install, check your master & slave & fluid and check w/ the installer & clutch mfg. on the pedal travel when it's brand new.
NVR BRNG is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • How do I know my clutch is slipping
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    01 C5Z, Clutch Pedal Stiff/Sticking RXPX C5 Tech 10 09-07-2015 04:08 PM
    Clutch pedal stuck to the floor and puddle under car. stephenpen C6 Tech/Performance 9 02-19-2015 12:12 PM
    clutch pedel who928 C5 General 5 02-14-2015 03:21 PM
    2006 clutch problem??? C6vettegfw C6 Tech/Performance 0 08-09-2014 02:21 AM
    Foot slips on clutch pedal 1 BAD 9T9 C5 General 19 04-30-2014 07:31 PM
    Tags
    cluch, corvette, sliping
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
