Feeling the need to stroke it? Lunati kits inside!
Location: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
1 Post
St. Jude Donor '06-'07
Lunati currently has 14 different LS1 and LS6 rotating assemblies available and they will have two new kits coming soon. The Lunati engine assemblies are made with the finest Lunati engine components, including a Lunati Pro-Series crankshaft, Lunati Pro-Billet connecting rods, Lunati forged pistons, rings, bearings, and piston pins.
If a turbo or blower is to be used, they recommend 8.5 CR with pump gas. For racing and race fuel you can move to 12.5 CR for maximum performance. The pistons and rings come in 0.005" oversize to accommodate honing to clean up the cylinders. The top ring is a 1.5 mm moly plasma pre gapped ring, second ring is 1.5 mm cast-iron reverse-twist, and the oil ring is 3 mm three-piece. The assembly is internally balanced and the reluctor ring is installed. All this, and with your choice of up to 408 cubic inches!
We are offering discounts on all of the Lunati stroker kits and cams that they produce. Pistons, rods, ect... can also be purchased seperate. Pricing is available by e-mailing tbyrne@tbyrne.com or give Julie a call at 1-508-678-2071- Monday - Friday.
Have a good day!
Tom
[Modified by tbyrne, 12:18 AM 12/20/2003]
Re: Feeling the need to stroke it? Lunati kits inside! (tbyrne)
:eek: :eek: very nice goodies there.......lets see how long my stock bottom end lasts with the blower on it :D :D :D a 408 with lots of boost would be pretty nice :cheers:
[Modified by corvette184, 4:20 AM 12/20/2003]
CI 3-4-5-6-10 Veteran
St. Jude Donor '03-'06-'08-'09-'10
Re: Feeling the need to stroke it? Lunati kits inside! (corvette184)
This is a stroker kit! :lol: :lol: :lol: :lol: :lol:
I am a sick biatch! :yesnod:
[Modified by IMQUIK, 2:13 AM 12/20/2003]
Re: Feeling the need to stroke it? Lunati kits inside! (IMQUIK)
Re: Feeling the need to stroke it? Lunati kits inside! (rwj383)
:iagree: Both kits provide HOURS of enjoyment! :rofl: Just always remember........ Friction is the enemy. :D
Hey, when it comes to installing a stroker do you need to "clearance" the block? If so, at what size does it become necessary (i.e. 383, 408, etc.) & can you do it at home or does it require special tools?
I have an '01 that is soon to be ATI blown, with all the talk about oil consumption with my year car, a rebuild may be in order. :sad:
1 Post
Tom..I can't recommend the Lunati Product line enough :smash:..I'm a true believer their excellance in quality! :yesnod: I've had all success with the stroker kit and cam..Just a real assurance that the product does what the manufacturer say's it does :thumbs: I hope you sell a bunch !!
Re: Feeling the need to stroke it? Lunati kits inside! (red1vette)
Nice kit, but you'll make better power with an "all bore" motor for close to the same money!
1 Post
Re: Feeling the need to stroke it? Lunati kits inside! (vstella)
The new LS1 kits are -
EA035-427 LS1 Engine Assembly 427CID 10.6:1
EA035-434 LS1 Engine Assembly 434CID 10.6:1
EA035-447 LS1 Engine Assembly 447CID 10.6:1
And for the LS6 -
EA135-427 LS6 Engine Assembly 427CID 10.6:1
Tom
And for the LS6 -
Tom
