DIC Code P1416 Air system bank 2?
Ok my engine light came on and the only current code is 10 PCM P1416 H C:banghead:
Which as I understand it means some kind of issue with air system bank 2.
Can someone explain what exactly that means and how big of an issue it is? Is it safe to drive the car with this issue?
Thanks in advance.
Thanks in advance.
Re: DIC Code P1416 Air system bank 2? (flynbludream)
Thanks in advance.
Thanks in advance.
your code means either the valve on back 2 is not working anymore, kink in the air path...
common fail.. means passenger side (bank 2) air check valve is going/gone bad.. $12 to 15 at Napa if it keeps giving you trouble..
Re: DIC Code P1416 Air system bank 2? (99blackFRC)
It's usually a rusted check valve. The bummer is that to replace the passenger side valve you have to remove the intake manifold.
