c5 6 speed conversion
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
Re: c5 6 speed conversion (99LS1VETTE)
My car goes in Monday to A.R.E for this conversion. I bought ALL the parts myself from various vendors. Karshop, ValveGod, Crashed 94.
Parts needed:
Tranny
Torque Tube
Bellhousing
Tranny wire harness
Shifter
Shifter rod and linkage
Shifter boot
Clutch
Master Cylinder
Slave Cylinder
Clutch and brake pedals
[Modified by Buckmaster, 7:02 PM 1/14/2004]
Parts needed:
Tranny
Torque Tube
Bellhousing
Tranny wire harness
Shifter
Shifter boot
Clutch
Master Cylinder
Slave Cylinder
Does anyone know of a 6 speed conversion for a c5? My 4L60E went out so now is a good time to change if available.
Re: c5 6 speed conversion (Buckmaster)
I'm in the process of it right now. Hey Buckmaster, could you do me a HUGE favor and post a pic of the trans. harness??? I've been told it connects to the ECM harness but my search has came up empty handed!
Cruise-In V Veteran
Re: c5 6 speed conversion (98VETTEC5)
Damn....I don't have a digital. Sorry.
Cruise-In V Veteran
Hmmmmmmmm. Long. Maybe 5+ feet? There are quite a few connectors too :crazy: Sorry I can't get specific. It's all bundled up for A.R.E. Monday. Looks complicated to me. :crazy:
Cruise-In V Veteran
I'm trying to find it in my manual now.............................
Cruise-In V Veteran
I have the wiring schematics. I can fax them to you tomorrow if you want. Let me know and IM me a fax number.
I was told you don't have to have a diffrent wiring harness if you are going to a manual. Is this correct?? I'm trading with a guy in Dallas (goldmember) and we thought that he needs my auto harness but I don't need one from him?? Any ideas??
Cruise-In V Veteran
Well..............if you have Active Handling I believe you need a harness that has it! Also the M6 harness will have a skip shift connector, a reverse inhibitor connector, etc....I am certain you need a M6 tranny harness!!!!!
Thanks but I have the diagrams- I was thinking that it was a small piece that just plugged into the harness- but I think that it is the whole harness!!
St. Jude Donor '06-'07-'08
We did this for my wife's '02 vert. Buckmaster's list seems to be pretty complete...regarding the harness, I think you definitely needs the trans harness, which is probably about 4 or 5 feet long. You do not need to replace the body/dash harness (which is good, 'cause that would be a major PITA!!).
We got all of our parts from Gene's Kar Shop - I'd definitely recommend using him. He can get everything you'd need, and he'll stand behind what he sells you.
It actually turned out to be less work that we thought; it's not as crazy a change as everybody thinks it will be! :D Plus you can go with a Z06 trans if you want to (we did), which is pretty cool. The other thing you'll have to do is get your computer reprogrammed; if you know someone at a local dealer, they may be able to help you out with this.
Good luck,
Collin
Good luck,
Collin
If you not mind me asking I been thinking about this, what did you pay in parts for all of this, PM me if you do not wanna say on here. I really miss my M6 from my Z28 figured I may do this for the C5. Thanks guys
Cruise-In V Veteran
I could be wrong but I don't think the tranny harness has those connections. It has quite a few connectors on it and will run the length of the tranny, torque tube and into the appropriate connectors in the engine bay area or around there. It is a quite large wire harness.
You guys mean the harness that plugs into the abs and above the battery right??
Cruise-In V Veteran
Re: c5 6 speed conversion (BadMonkey)
It all depends on if you go with any upgraded parts such as a clutch and tranny. I went with an upgraded clutch and tranny but everything else is stock. If you go with ALL stock parts....it will be about $2000.
