Which Oil Filter to use ?? PF44 or PF46
Went to my local parts store today that carries the AC Delco oil filters and they do not stock the PF 44 called for in my owners manual. They showed a PF 46 as a replacement. Is this correct????
Re: Which Oil Filter to use ?? PF44 or PF46 (Mac78and2K)
Never heard of a PF46 before. I use the UPF44 Ultraguard on mine. I haven't seen these in auto parts stores and some of my local dealers look with the 'deer in the headlights' look when I ask them about one. You can get them at a discount from Fichtner Chev or possibly GMPartsDirect.com.
Re: Which Oil Filter to use ?? PF44 or PF46 (ClarksZ06)
Yes, The number used to be 44 and was changed to 46. They are exactly the same filter.
Re: Which Oil Filter to use ?? PF44 or PF46 (MNElectronBlue2002)
Re: Which Oil Filter to use ?? PF44 or PF46 (jdetar)
The mobil1 is a good alternative as well.
Re: Which Oil Filter to use ?? PF44 or PF46 (Patman)
Independant tests have shown the Mobil 1 doesn't flow as well as other filters, which is very critical in an engine which sees a lot of full throttle. The K&N HP1007 filter is one of the best flowing filters you can get.
I will use the AC Delco Ultragard Gold UPF44 on my vette .......... best filter around .......... my second choice would be a WIX or NAPA Gold ..............
Learn more about lubrication and filtration here:
http://theoildrop.server101.com/ubb/ultimatebb.php
hrm.. interesting! I just heard the Mobil1 filters very well.. wasn't sure about the flow issue. Where can you get K&N oil filters? I've yet to ever see one locally.
Received 19,293 Likes
'20-'21-'22-'23-'24
PF 46 is the new number for the old PF 44.
Re: Which Oil Filter to use ?? PF44 or PF46 (Airwilf)
What do you guys pay for the UPF 44???? Please post your price and source!!
Am using the UPF44 from Ken Fitchner Chev. I buy them by the 6 pack
Re: Which Oil Filter to use ?? PF44 or PF46 (Alex D)
http://temp.corvetteforum.net/c5/ken...rtspage8.shtml
6.75 each in lot of 6 plus shipping. Best deal.
Former Vendor
Re: Which Oil Filter to use ?? PF44 or PF46 (kenrobb)
We use UPF44 Ultraguard Gold, Part number 25329389 in our Z06.
$ 6.09 EACH It's best to order a case of 6, cost is $44.49 TOTAL price shipped to your front door
Thanks, Marc
TECH 1794 http://WWW.GMPartsDirect.com
http://www.gmpartsdirect.com/results...&partnumber=C5
Thanks, Marc
Veteran
Re: Which Oil Filter to use ?? PF44 or PF46 (EFI-1)
:iagree: K&N HP1007 is an awesome filter for about the same price as the Mobil. Patman would know.... :yesnod:
Patman convinced me to switch and I do see an increase in oil pressure.
