BCM : Body Control Module
I have a 99 Vette and was told by the dealer that my BCM lost its programming and needs to be replaced. I asked them to reprogrammed it, but was told that the BCM can not be reprogramed or reset. Is this true?
[Modified by Robert L Lucien Jr, 7:16 AM 4/15/2004]
Re: BCM : Body Control Module (Robert L Lucien Jr)
I have a 99 Vette and was told by the dealer that my BCM lost its programming and needs to be replaced. I asked them to reprogrammed it, but was told that the BCM can not be reprogramed or reset. Is this true? ......
Also, if your ignition key is replaced, the BCM must be programmed to accept the resistance value of the new key. BCMs do get programmed.
Perhaps there is a miscommunication between you and the dealer. Perhaps the current BCM has a problem and will not accept programming.
Otherwise, I would look for another service facility.
