can I replace the bulb for the check engine light?
Old 04-21-2004, 11:08 AM
highpressuremax
highpressuremax's Avatar
Default can I replace the bulb for the check engine light?
When I start my car, all of the guage lights work except for the check engine light. anyone ever change out this bulb, do I need to pull the guage cluster and get behind the guages? :confused:
Old 04-22-2004, 12:26 AM
JTE
JTE's Avatar
CI 4-7, 9 & 10 Veteran
Default Re: can I replace the bulb for the check engine light? (highpressuremax)
:yesnod:
Old 05-01-2004, 01:19 AM
T_Vert
T_Vert's Avatar
Default Re: can I replace the bulb for the check engine light? (JTE)
could someone show me a pic of where the CE light is? I have a check gauges light but no CE light.
Old 07-01-2013, 08:03 PM
93civEJ1
93civEJ1's Avatar
Mine is the same way. I have my cluster out but the bulb is there. Do some people turn them off somehow?
Old 07-02-2013, 06:30 AM
Dave-A
Dave-A's Avatar
St. Jude Donor '14
They can and do burn out.
Old 07-02-2013, 07:57 AM
vettenuts
vettenuts's Avatar
Not sure if they are soldered in. I just had my daughter's Envoy dash fixed and they also replaced all the bulbs because they are soldered to the printed circuit board.
Old 07-02-2013, 04:15 PM
93civEJ1
93civEJ1's Avatar
they are not soldered on our...they are twist in.
I purchased a #74 bulb for the CE light at advance auto...will swap it later...mine is burnt out..you can see where the bulb is bad.
Old 07-02-2013, 05:20 PM
vettenuts
vettenuts's Avatar
Good to know for future reference.
Old 07-04-2013, 07:54 AM
Dave-A
Dave-A's Avatar
St. Jude Donor '14
Are you confident that this is the correct bulb, or is it something you are going to try?
Old 07-04-2013, 09:13 PM
93civEJ1
93civEJ1's Avatar
pretty confident..saw it somewhere else...measured the bulb to the other and they appear the same size. I buttoned it up and tried it. I now have my light back.
To can I replace the bulb for the check engine light?
Quick Reply: can I replace the bulb for the check engine light?
