Help: Can I mix runflats with non-runflats?
I have a good pair of front runflats and I was just wondering if I can save some money and put non-runflats in the rear?
James
James
Bad idea. The differences in compound, sidewall hardness and handling will make it squirrley. A friend of mine did this and told me his handling went to Hades. Someone here recently tried it also and had the same result.
From what I've investigated, the handling dynamics between runflats and non runflats are completely different. I would imagine that this would hinder the overall performance of your vette. You would be much better off to change all of them to non-runflats, or just bite the bullet and get the runflat replacements.
Just my $.02.
Just my $.02.
1 Post
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
I'm running run-flats on rear and non on front both goodyear and same f1 tread pattern.Haven't had any issues but the tires have only been on two weeks.
Received 3,812 Likes
St. Jude Donor '03-'04
Not a good idea.. the side wall has a lot to do with handling characteristics.. in the case of a run flat, with a much stiffer side wall, and a non run flat, the car will not handle as well... It doesnt mean you cant get use to the difference... but it is generally not a good idea...
1 Post
Cruise-In V Veteran
hey we could swap my fronts for yours my fronts are 3 mos old.they we installed when i bought car
I'm running stock run flats up front and ecsta mx in the rear. It does emphasise how much the run flats suck, but I think the car handles better. Especially off the line. I am going to switch to the same tire up front in a while, but figured I would make sure I liked the rears before I changed all 4.
