Fuel Filter Location and Replacement
Old 08-26-2004, 11:57 PM
theloyster
theloyster's Avatar
Default Fuel Filter Location and Replacement
Where exactly is it located and how hard is it to replace? I was told that I should replace it. Any tips for the replacement?
Thanks alot.
Old 08-27-2004, 12:21 AM
vetterdstr
vetterdstr's Avatar
CA Events Coordinator
Here si a thread that has the info you need... http://forums.corvetteforum.com/showthread.php?t=880518
VR
Old 08-28-2004, 10:47 AM
Vector
Support Corvetteforum!
Vector's Avatar
Thanks alot.
Checked your sig. - a 2003 - unless you are really cranking alot of miles out why are you changing the fuel filter so soon? Might want to do a search to see want others are recommending on change intervals. I changed mine at 30K miles but it was 6.5 years old and found it only had the slighest restriction after I got it out.
BTW, if you change it - keep a rag handy, it's going to spill fuel on you.
Old 08-28-2004, 10:52 AM
Patches
Patches's Avatar
I agree - seems very early to be changing unless it's defective or damaged. Here's a pic of mine.
Old 08-28-2004, 11:03 AM
Rattler71
Rattler71's Avatar
The 2000 I had, had the original fuel filter. I changed it at 52000 miles and did not notice any difference. The filter was like $50.00, man that is like 10 Wendy's meals.
Scott
To Fuel Filter Location and Replacement
Quick Reply: Fuel Filter Location and Replacement
