Check engine light came on, please help with codes
Location: My barber didn't know when to quit... Do you?
My check engine light just came on and so I checked the codes, just wondering if any of the codes would have caused the light to come on and if it is serious.
I had the usual U1096 , etc codes all H
But some others I had were:
P0751 H C (don't know what this one is, do you?)
B2583 H Column lock/unlock drive. Don't know what this one means?
C 2115 H C (for my tire sensor that doen't work)
So would any of these codes set off the light or do I have to look elsewhere?
I would like to find out what the P0751 code means before I reset all the codes...
DTC P0751 1-2 Shift Solenoid Valve Performance. This code sets the check engine light.
Circuit description:
The 1-2 shift solenoid(SS) valve controls the flow acting on the 1-2 and 3-4 shift valves. The 1-2 SS valve is normaly-open exhaust valve that is used with the 2-3 valve, in order to allow four different shifting combinations.
When the PCM detects a 1-1-4-4 or a 2-2-3-3 shift pattern, depending on the state of the mechanical failure, then DTC P0751 sets. DTC P0751 is a type A DTC.
Thanks for the help!!
Now what does that mean exactly in terms of seriousness of the problem? Does it have to be fixed at once and what is the fix or could it be a one time thing that won't occur again?
I have an A4, 3500 converter, FLP trans...
The faulty solenoid is inside the transmission but I believe it can be replaced by dropping the tranny pan
Originally Posted by SERIOUS RACER
H MEANS ITS HAPPEN BEFORE I JUST WOULD RESET AND FORGET IF NOT GET SOMEONE WITH LS1 EDIT TO LOOK AT IT
