Magnasteer adjustment
CI 3, 4, 5, 6 & 10 Veteran
Does anyone know if the magnasteer can be adjusted to be more firm? We tried to find how to do it with a Tech II tonight but could only find how to test that the magnasteer functions. Thanks in advance.
Mike
Mike
Location: "Once you have flown, you will walk the earth with your eyes turned skyward; for there you have been
Yes the Magna Steer can be adjusted.. there are settings in the TECH2 that modify the firmness / speed sensitivity. I'll see if I can find the info I had on and post it so you can try again w/ TECH2.
Originally Posted by Ls1Rat
there is an add-on to the shop manual about this. It can't be adjusted.
Oh well, since this didn't pan out I guess I'll see what can be done by adjusting the alignment.
Thanks for the responses.
Mike
Everything is editable if it was written in computer language. I'm going to assume this applies for magnasteer settings as well. Some engineer wrote the code indicating how and when to firm up the steering based on various inputs. Therefore there has to be something that can read that portion of the ECM. May not necessarily be a Tech 2.
Mike, I called someone with some inside contacts regarding this. I'll let you know ASAP...
Mike
