ATI or Fluidampr for damper?
Old 11-23-2004, 12:10 PM
Hell-bent
Hell-bent's Avatar
Default ATI or Fluidampr for damper?
I want to upgrade to an aftermarket crank pulley/damper for high RPM driving and can't decide between the ATI and Fluidampr. Can anyone give me a good reason to go with one or the other?
Old 11-23-2004, 02:29 PM
corvettebob1
corvettebob1's Avatar
Yep when I looked into this about a year ago fluid damper did not make one for the LS1.
Besides the ATI unit is rebuildable and has been the choice for NASCAR for a long time.
And no matter what you use, PIN THE CRANK!
ATI also makes a nice kit for this too.
Old 11-23-2004, 02:55 PM
wrustywrench
wrustywrench's Avatar
for the vette, without a doubt (mine anyway) go with the ati. Rebuidable, and a better unit than silicone.......(silicone is for *******)
Old 11-23-2004, 03:03 PM
joghotrod
joghotrod's Avatar
ATI for sure.
Old 11-23-2004, 03:06 PM
leaftye
leaftye's Avatar
It'd make the Vette that much more enjoyable to drive!
Old 11-23-2004, 03:07 PM
Pumba
Support Corvetteforum!
Pumba's Avatar
I am installing an ATI.
In addition to NASCAR, the C5R Racing Team uses ATI dampers. I agree with the pinning, and I would also recommend that you look into a Katech adjustable, billet belt tensioner - www.katechengines.com
Good luck with your decision.
Old 11-23-2004, 08:06 PM
Hell-bent
Hell-bent's Avatar
Seems like ATI is the only one people drop money on. Sure looks like a nice piece and I hope it helps the engine live a long life at 7000rpm!
Old 11-24-2004, 06:24 AM
XTrooper
XTrooper's Avatar
ATI.
See sig.
Old 11-24-2004, 07:29 PM
Hell-bent
Hell-bent's Avatar
Are you guys using the steel or aluminum (lighter) ATI?
Old 11-25-2004, 11:52 AM
corvettebob1
Steel here
Old 11-25-2004, 11:54 PM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
Steel hub here with the Aluminum shell - 10% underdrive SuperDamper.
FWIW- ATI only makes the Aluminum hub for LS1s without A/C or with Dry Sump setups.
The 10% Underdrive Shells are Only available in Aluminum for the LS1.
Old 11-26-2004, 07:46 AM
XTrooper
XTrooper's Avatar
Ditto.
Old 11-26-2004, 06:15 PM
myblackC5
myblackC5's Avatar
Default fluidamper
......fluidamper claims 12 hp, extra because there quiet.
Old 11-28-2004, 08:03 PM
Hell-bent
Hell-bent's Avatar
No doubt that is a bogus claim. I am going to try the ATI but am still confused about the steel vs. aluminum. Who would ever want the 3lb heavier steel version at the same price? I wonder why they even offer the choice ?
Old 11-28-2004, 08:29 PM
vettemaster1
vettemaster1's Avatar
i just installed underdrive fluidampr and it looks, installed and seems to work well....
i also think they are like comparing apples to oranges....while they both dampen harmonic vibrations..they use different method of doing it...ati is more conventional with outer inertia ring bonded to inner hub...the fluidampr has internal inertia ring suspended in high viscous silicone..
either one is good choice...lighter weight means quicker acceleration>>>>always a good thing>>>
Old 11-29-2004, 02:45 PM
corvettebob1
When I purchased mine I asked that same question, seems the aluminum one also has an aluminum hub.
Not for the street, get the steel one!
Old 12-01-2004, 03:52 PM
Hell-bent
Hell-bent's Avatar
What am I missing here? What would be bad about the lighter weight aluminum hub on a street car? Seems the lighter pulley would be better!
To ATI or Fluidampr for damper?
Old 12-01-2004, 09:17 PM
leaftye
leaftye's Avatar
I'm curious too. Track-only parts often perform quite well, but sometimes don't work well for extended periods (Mezeire waterpump), fatigue or wear out over time (Ti connecting rods or valves) or are noisy (trannies with straightcut gears). Does the AL unit do any of these things?
Old 12-01-2004, 09:42 PM
vetterdstr
vetterdstr's Avatar
CA Events Coordinator
I have the ATI dampner on my car (steel) with the 8 rib. Here are a few links for you to check out when considering the ATI unit and why it is my number one pick. http://www.atiperformanceproducts.co...amper_tech.htm
http://www.atiperformanceproducts.co...mper_dinan.htm
VR
Old 12-01-2004, 11:13 PM
vettemaster1
just to play devils advocate check out this link also.....
http://www.fluidampr.com/torsional_vibration.htm
Quick Reply: ATI or Fluidampr for damper?
