Pulsating brakes - not warped
I know from this:
http://www.stoptech.com/whitepapers/...otors_myth.htm
That it's unlikely my rotors are warped. I bet it's just buildup. This site, and a couple other sites, say to use garnet paper. Well, I'm not exactly sure what garnet paper is, or where to get some. So the question is, can I use steel wool? With iron rotors and semi-metallic pads I don't see what the problem would be. If I must use garnet paper, please let me know where to look for it. On another site it said to pick up 100A grit paper. Thanks!
Have you changed pads recently??
I think the first thing I would do is go rebed your pads.
Go find a nice low traffic long straight road.
take the car up to 40 mph then stomp on the brakes. Stomp on the brake peddle very hard, almost hard enough to activate ABS, but not quite.
40 to 5 mph and do this three to 5 times.
Then 80 to 5 mph 4 to 5 times.
Drive the car around for 30 to 40 min at a relitively legal normal speed to cool the rotors and brake pads.
Put the car away for 24 hours ( not over night ) to continue the cooling process. do not set e-brake.
Then see if the pads still pusate after this procedure.
Good luck
Good luck
i did what was stated above and my problem went away for a few days but came back. Any ideas why? I know its the pads as the rotors are new.
Dave
Dave
What pads and rotors are you using??
When you change pads or rotors you should change one or the other, not both at the same time. But if you must change both pads and rotors at the same time, then do it. It is really not a good idea to use different pad material on the same rotor. If yo uare changing to a new pad get new rotors. Rotors are cheap. Raybestos rotors $25 each at NAPA. No need to spend any more then that unless you want the drilled and slotted. Also at NAPA Raybestos D&S at $50 each. Rember no D&S for track days.
The other possibility is that the pistons do not push all the way back in. When changing pads clean the piston boots and pistons as best as possible and put a little grease on the piston. This will allow the piston to to move in and out easer.
Also always bleed your brakes when changing one or the other. It is a good time to do so and your right there anyway.
There is a lot of good info on the Stoptech site.
http://www.stoptech.com/whitepapers...rotors_myth.htm
The Wilwood site also has lots of good info
http://www.wilwood.com
I didn't change my pads recently, although I do have a new set of Napa rotors and PFC-Z pads sitting on the shelf. I know those things are going to develop pulsing occasionally, no matter how careful I try to be. As cheap as rotors are, I still don't want to swap rotors every time they start pulsing, especially since that means having to rebed that rotors/pads. My goal today was to try to get rid of the pulsing without risking a ticket by rebedding them. I took some steel wool to the rotors and lightly sanding them, the goal being to get rid of highspots from pad buildup. I bled the brakes and took it for a test drive. So far it seems fine. I did lots of 35 mph to 0, and one 55 mph to 0. Not much of a test, but I have plenty of braking to do on the way to work tomorrow, so I'll know if it worked for sure tomorrow morning.
Take it to 180 MPH and then test the ABS it will clear everything after ten cycles Only kidding. i used to swap the pads and rotors as sets keeping all things as they were on the car when reinstalling them.
Sorry to continue in this thread, but.. lol
AU, i have sportbrakes rotors and OEM pads front/rear. The problem was there before changing rotors.
Dave
Dave
Dave
That is ok to continue the thread. We all learn by asking questions.
I have a few questions for you, if you dont mind?
Where your pads even thickness when you put the new rotors on??
and did you "bed" the rotors in as described above??
How are your caliper pistons?? do they move in and out smoothly or do they need to e cleaned and a little grease put on??
these answeres will help with understanding your problem.
Tom
Tom
I'll share my experience..
I have the Sportbrake dimpled rotors, and Performance Friction Z-rated pads..
This set up is great on the street, no noise, excellent stopping power..
Took the car to the track (Talladega G.P.), and by the second session, about mid way through (10 mins), I started getting a fairly significant vibration thru the steering wheel / pulsing thru the pedal..
After allowing the brakes to cool, (came off the hot-lap pace) everything returned to normal.
3rd session, same thing again, backed off, everything came back.
Kind of disappointing seeing how this brake issue impeded my attempts to turn lower lap times.. Oh well. But I certainly did not want to trash my relatively new brake set up.. (BTW, this combo had at least 500 miles on it before this track day)
I'm guessing this was a pad problem (i.e. I need to run a more track-oriented compound), but I'm not entirely sure.
Thanks Dan good info
Yes it is difficult to find a pad that can be used both for street and agressive track braking. Most ppl change pads back and forth.
I use the Raybestos rotors and Wilwood "H" pad with Catrol SRF brake fluid. Great combination as it stops exeptionaly well ( I think better then the PFC01 pads I use to use) very minimal fade or pad ware.
Some times it feels like I am doing a 'stoppie' when I stomp on the brakes at 135 mph down to 60 mph to take a corner. I feel the rear wheels get very light.
I do minimal street driving with my car so I dont change pads or rotors and dont do any last minute braking on the street either.
Originally Posted by AU N EGL
Dave
Tom
Tom
Dave
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
Originally Posted by leaftye
I know from this:
Dave
Dave
no seriously did you?
i used to change the rotors on my cavalier every 3k cause i never torqued the wheels
oh well lifetime warranty
but serioulsy aluminum wheels dont mix well with over torqued lugs
