Bad rear wheel bearing??
What does a bad rear wheel bearing sound like? I have a scratching sound coming from the rear of my car that gets louder when you turn to the left. Could this be a bad bearing?
Phil
Phil
Usually you will hear it more going around turns then in a straight line.
Also if you jack the rear you would have some play if you grab the tire at the top/bottom I believe.
