Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: General How-Tos
- C5 Corvette: General Specifications and Information
Important information to help you understand your Corvette.
Weights, measurements, ratios, strengths, etc
Received 19,303 Likes
'20-'21-'22-'23-'24
Great informative thread. Thanks for all the info.
St. Jude Donor '03-'05-'06-'07
Eugene, you must eat, sleep, and dream Corvettes! Great information
thats easy to get too (yes, I bookmarked it)!! Thanks a lot!!
Holy cow. I mean great jumping horny toads.
One question -
On the note about transmission fluids, paper parts, synthetics, and the destruction thereof -
What constitutes an 'early' and a 'late' transmission? Does a 1999 car with manual trans have the paper parts?
About the headlight bezel plugs -
The old non-locking style are no longer available as a service part according to Bob at Fichter Chevrolet. I ordered two new locking plugs and the new headlight surrounds to convert my 1999 to the new style.
One question -
Thanks again guys! Vetteran, of course I am, the Corvette is a "dream" car after all! I have an update coming, but I'd like to have substantial additions before updating again. I'll post an update this weekend.
Here is a thread about the paper blocking plates I mentioned:
http://forums.corvetteforum.com/showthread.php?t=936671
Here's a thread about the Ford harness cutouts:
http://www.zo6vette.com/forums/showthread.php?t=71047
Here the site for bronze headlight gears:
http://www.rodneydickman.com
Bill Curlee has a great new thread about water leaks, and I know I have the shortcut on my desktop, but my desktop is a MESS. I'll post the link later.
Supporting Tuner
Awesome!! I saved this info into a PDF - this is valuable stuff!!!
Thanks for assembling it in one place!!
EG
EG
I incorporated as much as I could, but there's still much more to come!
Changes made:
Added more electrical ground information
Created water intrusion section
Created headlight gears section
Added part #'s to replace impact bar, and disclaimer about A&A scrape protection parts
Created tire hop section
Added information about inside/outside tire sping
Added information about the paper blocker rings and transmission fluids
Added Z06 windshield weight
Added hood (C5/CE) weights
Moved hood rattle information into a new section
Added information about faulty gas gauges
Added information about steering column lock problems
Created chassis stiffness post from thread in Autocross forum
Created rocker bearing failure section
created a recommended reading section
Added old, new and LG driveshaft specs
Still trying to find out more about the Ford harness cutouts, and haven't researched Kumho tire weight discrepencies.
Eugene
Changes made:
Eugene
#34
Brighter lights
Darnit, I just told someone I had some lighting info in this thread. If you come here looking for brighter lighting options, go here:
http://forums.corvetteforum.com/showthread.php?t=986978
The next update will include the information from that thread, and even a little more (like HIR bulbs).
Eugene
Eugene
#37
Great post. One SMALL note:
Rattling front speaker BOSE emblems: Take the door panel off, take the emblem off. Place small o-rings on each bendable post and reattach them. Chris
#39
1 Post
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Eugene, great job...
I had another problem for you - I am not sure how common it is but I've seen it more than a time or two. The symptom is cruise control not working. the cause is the brake light switch is out of adjustment.
Thanks again...
Thanks again...
