Need copy of HUD wiring diagram
St. Jude Donor '06
I am adding HUD to my 97. I upgraded to a HUD cluster this past summer. I have recieved my parts (screen,switch,bezel). I just need to make the 11 pin harness to jump the cluster to the switch. I will modify my current wiring, I just need to see the wiring diagram for this harness. I only have a 97 manual, with no HUD section. If you can post or email a copy of the diagram your help would be much appreciated.
Email: frankjr5@yahoo.com
Thanks, TommyN
Thanks, TommyN
I had the exact same problem when I was installing my HUD. I ended up buying the HUD projector, switch, and cable on eBay. Here is a pic of the cable installed on my 2001 Z06 instrument cluster. The first 7 wires are the same as a non HUD cable, you only have to add the last 4 wires.
