[Z06] Fred Beans November C5 Specials (Must Read)
Hi All,
Thank you for visiting our November specials. We have some exciting news. Our website is pretty operational at this point. It is a good tool for you to use to get pricing and to order when it is most convenient for you. There are a couple of minor issues to work on at this point and we will take care of them, but for the most part it is great!
You can view it at www.fredbeansgmparts.com
We have shopping cart technology, shipping quotes, create your own account, etc. It even has it’s own parts catalog. While it is one of the best parts catalogs I’ve ever used on the internet, we must be realistic and admit it is not like the GM catalog.
I’d like to discuss our pricing to you. On most items the price plus shipping comes out to what we would have quoted before over the phone. In some instances shipping may seem rather high. We do have noted towards the end of the checkout process that if an item seems unusually high with shipping please contact us. This could mean 1,000 body control module having charged 90.00 or 150.00 in shipping. We realize it probably would cost less than 20 to ship, so we’ll be happy to modify the pricing. The most important part to using our site is the quote on the part itself.
We have also gotten some price increases from GM November 1st and that is not reflected yet on the website on some items, but within a couple of days the prices will be updated. If there is a price adjustment or anything that is needed, we will notify you BEFORE charging you. Just as a note, the order put in by you online is not final and can be adjusted by us, with your permission first, or declined by you later. We do not charge your card for the order until both parties agree on the price with shipping, which this typically is not going to happen. It will normally be the price shipped which is quoted online.
You may call us or place your order online. The last comment I’d like to leave you with is that we will not be undersold. If you find the part on our site, less expensive anywhere else shipped, we will meet or beat that price.
Thank you. Last but not least if there are any issues with the site, please email me directly and do not clutter these sales threads.
-Gene
||--Genuine GM C6 Z06 Clutch Components--||
24233650 – LS7 Clutch
12571611 – LS7 Flywheel
Both LS7 Clutch and LS7 flywheel are 524.36 shipped.
For both clutch and flywheel on our website, use part number ls7clutchkit under Chevrolet make.
89059282 - LS6 Slave Cylinder – 101.83
12564455 - LS6 Master Cylinder – 103.86
14061685 – Pilot Bearing – 9.53
*Clutch does work in any LS1/LS6 drivetrain but must also have ls7 flywheel. Also, can only use LS1/LS6 hydraulics.
||--Genuine GM C6 Z06 Shifter Kit--||
15232011 – C6 Z06 shifter
10354701 – C6 shift ****
11609670 - Bolt
Complete kit 180.82 + 17.18 shipping!
For this kit on our website, use part number c6z06shifter under Chevrolet make.
||--Genuine GM C6 Shifter Kit--||
15232012 – C6 shifter
11609670 - Bolt
Both parts 209.00 + 19.86 shipping
For this kit on our website, use part number c6shifter under Chevrolet make.
||--Genuine GM Engines--||
12498399 – 2002 + LS6 engine – 5130.13
12480030 – GM Performance Parts C5R block – 6350.00
89017654 – LS2 engine – 4899! 400 below dealer cost!
12568950 – LS2 bare block – 959.99
12572808 – 6.0 cast iron bare block – 659.99
||--Genuine GM Z06 Suspension Components--||
Z06 caliper set – 384.28 shipped
For this kit on our website, use part number c5z06calipers under Chevrolet make.
Z06 front screens – 110.40 shipped
On our website, use part numbers 10424820 and 10424821 under Chevrolet make.
Z06 front brake ducts – 43.43 shipped
On our website, use part numbers 10295976 and 10295977 under Chevrolet make.
Z06 rear screens (scoops) – 133.41 shipped
On our website, use part numbers 10322761 and 10322762 under Chevrolet make.
Z06 rear brake ducts – 42.85 shipped
On our website, use part numbers 10425976 and 10425977 under Chevrolet make.
Z06 2004 shocks – 372.02 shipped
On our website, use part numbers 10339944 and 10339945 under Chevrolet make.
Z06 sway bar kit – 258.55 shipped
For this kit on our website, use part number c5z06bars under Chevrolet make.
Z06 sway bar kit (insulators and bars only, no end links) – 181.79 shipped
For this kit on our website, use part number c5z06barsNL under Chevrolet make. NL stands for no end links.
Z06 front brake pads – 88952008 – 111.61
Z06 rear brake pads – 12530688 – 52.22
Z06 rear differential assembly – 12572683 – 1106.16 shipped
Z06 front suspension spring – 22178729 - 436.91 shipped
Z06 rear suspension spring – 22188038 – 436.91 shipped
||--Genuine GM HUD Setup--||
10279814 – HUD
12198648 – Switch
10425223 – Bezel
Total setup is 297.03 shipped!
||--Genuine GM Tire Pressure Sensors/TPM--||
2001-2004 Sensors
25773946 - sensor – 30.72 each
15125473 - nuts – 2.66 each
Total setup of 4 is 146.20 shipped
97-2000 Sensors
10438853 - sensor – 74.61 each
10268439 - nut – 1.36 each (5 pack)
10268438 - washer – 1.36 each (5 pack)
Total setup of 4 is 341.68 shipped
||--Genuine GM Corvette Clutch Parts--||
12570806 - LS6 Clutch Kit – 369.99
14061685 – LS1/LS6 Pilot Bearing – 9.53
||--Genuine GM LS2 Items--||
89017648 – LS2 intake manifold – 248.13
12570790 – LS2 throttle body – 245.05
12572174 – LS2 fuel rails – 110.42
89017587 – LS2 injector o-rings – 20.89
||--Genuine GM LS6 Intake Manifold--
88894339 - Intake Manifold Only - 425.28!!
Intake with coolant pipe and plugs – 455.74 + 12.50 shipping.
For website ordering use part numbers:
88894339 – Intake
12581213 – Coolant Pipe
12570678 – Coolant Plug Qty 2
Online orders will show higher than 12.50 shipping. We will adjust the shipping charge after your order is placed.
||--Genuine GM UltraGuard UPF 44 Oil Filters--
25329389 - UPF 44 Oil Filter
Must order in cases of 6 @ 50.19 shipped!!
||--Genuine GM Cylinder Head Bolts And Gasket Kits--||
12498543 - 97-01 LS1 Engine Head Gaskets (2) – 33.48
12498544 - 02-04 LS1 & LS6 Engine Head Gaskets (2) – 23.86
12498545 - 97-12/03 LS1 & LS6 Engine Head Bolts – 16.21 per head
17800568 – 01/04 – present LS1/LS6/LS2 Head Bolts – 15.66 per head
If you’re not sure which bolt kit to use please email us your VIN# and we’ll tell you!
||--Genuine GM Ceramic Brake Pads--||
88909667 – Front ceramic pad kit
88909668 – Rear ceramic pad kit
Both front and rear ceramic pad kits 113.53 shipped!
||--Genuine GM Brake Rotors--||
OEM
10445856 – RF rotor
10445857 – LF rotor
10445858 – RR rotor
10445859 – LR rotor
Front and rear rotor sets 260.04 shipped!
AC Delco Performance Drilled/Slotted
88926731 – RF rotor
88926732 – LF rotor
88926733 – RR rotor
88926734 – LR rotor
Front and rear rotor sets 247.10 shipped!
||--Genuine GM T1 Engine/Suspension Items--||
T1 shocks – 583.48 + 28.50 shipping
T1 trans cooler – 877.68 + 28.50 shipping
T1 sway bar pkg with insulators and end links – 624.89 + 55.00 shipping
T1 complete suspension package – 2556.72 + 75.00 shipping
T1 suspension springs 696.17 each + 28.50 shipping each
||--Genuine GM Engine Parts--||
12564824 - '02 LS6 Cylinder Head (Assembly) – 729.75
12564825 - '02 LS6 Cylinder Head (Bare) – 535.66
12480110 - ASA Racing Cam - 375.87
12480033 - LS1 Hotcam Kit - 430.61
88958622 - LS6 CNC Ported Cylinder Head (Assembly) - 989.99 each!!
||--Helms Service Manuals--||
'97'- '05 Corvette - 124.95 shipped!!
Please Call For Any Other Make/Model Vehicle!
For ordering service manuals on our website, use part number helms manuals under the Chevrolet make. Please include year, make and model in the comments section.
||--Genuine GM LS1/LS6 Fuel Rail Covers--||
12559261 - '97-'98 LH Fuel Rail Cover (Black With Red "Corvette" Lettering)
12556455 - '97-'98 RH Fuel Rail Cover (Black With Red "Corvette" Lettering)
Both FRC’s 50.78 + 7.95 shipping
12561503 - '99-'02 LH Fuel Rail Cover (Black with Red "Corvette" Lettering)
12561502 - '99-'02 RH Fuel Rail Cover (Black with Red "Corvette" Lettering)
Both FRC’s 60.62 + 7.95 shipping
12564257 - '01-'02 LH Fuel Rail Cover (Red With Black "Corvette" Lettering)
12564258 - '01-'02 RH Fuel Rail Cover (Red With Black "Corvette" Lettering)
Both FRC’s 89.58 + 8.51 shipping
Fred Beans Pontiac Buick GMC Terms And Conditions Of All Sales:
We reserve the right to change the price of any part at any time and/or refuse to sell a part for any reason at any time. Price changes that can be made through the month are final and all sales before and after the price change are final. We will accept no returns after 30 days and all boxes or packages must be in the same condition as which they were received. If a package is received in anything other than perfect manner, please call and note upon receipt. Anything noted after the fact is the responsibility of the buyer. All returns are subject to a 20% restocking fee and/or a fee for unacceptable boxing or packaging. We reserve the right to change the terms and conditions of a sale at any time for any reason.
-Gene
11609670 - Bolt
11609670 - Bolt
10279814 – HUD
12198648 – Switch
10425223 – Bezel
2001-2004 Sensors
97-2000 Sensors
88894339 – Intake
OEM
10445856 – RF rotor
10445857 – LF rotor
10445858 – RR rotor
10445859 – LR rotor
88926731 – RF rotor
88926732 – LF rotor
88926733 – RR rotor
88926734 – LR rotor
Hi All,
We will be offering the z06 brakes as a pre-sale on our website soon. I'm getting an anonymous number of sets and I'll sell up to that amount. Keep your eyes peeled!
-Gene
-Gene
Originally Posted by Gene@FredBeans
Hi All,
Maybe it's because I tried accessing your site @ work, but I get one of those "this link isn't working...deal with it" msgs when I go to the URL. Is the site up and running this morning?
Or, is the URL supposed to be http://www.fredbeansparts.com/ (w/o the "gm" in it)?
Thanks!
CI 4-5-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11
Originally Posted by kedvesh
Gene,
Thanks!
Thanks!
Just recived my LS7 clutch kit and C6 hydraulics from fred Beans today.
I gotta give Gene a personal Thank You for the best customer care I've had in a long time not to mention he beat everybody's price by more then 50%. Fantastic service, Thanks Gene.
Thank you for your business. I do appreciate it. Good luck with your clutch and let us know how you make out.
Thanks,
Gene
Originally Posted by snide
The URL, as Gene posted, worked for me. Must be (L)user error.
Site works for me now. Guess the stars weren't aligned this morning.
